Results 1 to 25 of 41
chain
    Tougher than a lion Sportygurl131's Avatar
    Billerica MA
    chain
    ok another newb or blonde question
    my sprokets look good
    but ive noticed my chain is slacking (had it tightened)
    and it looks a lil kinky
    time to replace?
    Quote Originally Posted by DuncanMoto
    Subaru love is so sweet.
    qoute from a fellow nesrian
    You crazy bitch!!
    2003 sv650s copper!
    Quote Originally Posted by Duffy View Post
    Sportygurl is probably your best bet for meeting and making new friends, she is like the social director or ambassador or something for NESR.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: chain
    most chains I see are to tight! chains stretch, but if ya take care of um they last good. I used ta use kero now I just use the wax ta clean um! I have ta look @ it ta see if shot.
    www.bostonmoto.com
    Forum Rules
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: chain
    If you have a rear stand lift it up and check it all the way around (wiggle each link to make sure they are not seized up). If you don't have a rear stand have a friend lean it over using the kick stand so the rear wheel is in the air and do the same thing. As long as all of the links move freely its fine - unless it is stretched too far, your swing arm should have a sticker on it showing where the chain should reach if it is within spec.
    The other thing to check is that the chain is on the sprockets correctly. One side of the chain will always be a little tighter than the other as you spin it around and check, but I have seen where a sprocket skipped and the result is one side of the chain is very tight and the other too loose.
    If everything checks out just lube it up and be done with it.
    TWINS! xrocket21's Avatar
    Central Maine
    Re: chain
    be acareful not to lose a finger screwing with your chain!
    May 2002
    Meriden CT
    Re: chain
    be careful
    www.bostonmoto.com
    Forum Rules
    Billerica MA
    Re: chain
    ive cleaned it before! i dont stick my fingers near the chain... unless teh bike is off and not moving
    You crazy bitch!!
    2003 sv650s copper!
    May 2002
    Meriden CT
    Re: chain
    You can stop @ my place, & I will look!
    www.bostonmoto.com
    Forum Rules
    Billerica MA
    Re: chain
    Quote Originally Posted by beet View Post
    :wubs: hehe ur too far!
    You crazy bitch!!
    2003 sv650s copper!
    Re: chain
    The way to check is to try to pull the chain away from the sprocket towards the back of the bike. If the chain has some slack at the back of the sprocket, it is stretched and needs replacing. I let mine go until I can see 1/4 inch of daylight between the sprocket and chain at the deepest part of the valley.
    May 2002
    Meriden CT
    Re: chain
    There's a chain stretch gauge we use on fork trucks. http://www.drivesinc.com/roller-PDFs...r%20drives.pdf not this one but kinda
    www.bostonmoto.com
    Forum Rules
    May 2007
    Southern NH
    Re: chain
    Too tight is worst than too loose...up to a point of course.
    Find a place that looks 'kinky' and push it up and down. It the 'kink' is just because it's dirty...or chain wax build up...it will 'unkink' when you do this. If it doesn't then it's probably shot and needs to be replaced...
    Muhammad Ali.
    Member dodge1478's Avatar
    Apr 2010
    ma.
    Re: chain
    sporty girl - I like kinky!......oh you meant your chain...my bad!
    Just Registered
    Is it not obvious?
    Re: chain
    www.gpsdiscussion.com
    motorcycleaddicts.org
    May 2007
    Southern NH
    Re: chain
    Couldn't it just need adjusting?
    Muhammad Ali.
    Re: chain
    No, I'm pulling the chain on the middle of the sprocket. Adjustment has no effect here because the teeth are holding it in place. This is a quick way to measure stretch.
    Just ask, Be surprised!
    Jan 2009
    Salem, MA
    Re: chain
    lets say I took the wheel off to have the tire changed. and I am now putting the wheel back on. How do I know that I have the proper amount of tension put back in the chain?
    If I am pulling on the chain as it is wrapped around the rear sprocket, where am I pulling if the sprocket is related to a clock, such as the back most part of the sprocket is 3p.
    thanks..
    kinky is good, so long as it is not your chain.
    Lifer BostonSVkid's Avatar
    Dec 2005
    Re: chain
    Typically the manual tells you what kind of movement you should have in teh chain
    I tyicall go 1" to 1.25" of play. You can check this with the bike on the ground or on a stand. Put a ruler behind the chain (on the under side of the swing arm) somehwere in the middle (just eyeball it). Then lift the chain up with your finger. If it moves over 1.25" i tighten it a bit. If you have under 1" then your chain could wear out early and stretch out faster.
    2006 Ducati Monster S2R800
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: chain
    i've actually helped in adjusting your chain what was it maybe a month ago now. It looked good then. Might just need to be lubed again. It was VERY loose when we adjusted it so who knows lol
    i'll take a look at it next time i see it. got to do a little work on my bike so if its at the barn that will be very soon as i have a track day next wednesday
    www.bostonmoto.com
    Ride to live, live to ride
    Banned G21forme's Avatar
    Lakes
    Re: chain
    That is going to be one tight chain if it only has 1.25" of slack.
    Lifer DuncanMoto's Avatar
    Re: chain
    You can always come visit me and I'll check it without harassing you sexually....
    That's Komaki's job.
    thinks he wants a FZ6 intergalactic's Avatar
    Southern NH
    Re: chain
    As much as I hate the feeling of a lot of chain slack, the alternative is that as the suspension moves through its range, it tightens the chain, and if you don't have the slack, the force in the chain gets VERY high.
    This damages the chain and can damage the transmission by pulling very hard on the output shaft. The transmission and engine share castings on many (most) bikes, and damaging this is really expensive.
    Err on the side of loose, I say.
    Re: chain
    Quote Originally Posted by DuncanMoto View Post
    She gives great hugs.
    Grafton, Ma
    Re: chain
    I just looked at your chain it is a bit loose i'll tighten it up tomorrow if your bikes still in the barn. Doesn't look like it needs to be replaced tho, ill check for tight spots.
    www.bostonmoto.com
    Billerica MA
    Re: chain
    Quote Originally Posted by Danz19899 View Post
    your awesome... i think i need to clean it completely then relube it
    You crazy bitch!!
    2003 sv650s copper!
    Billerica MA
    Re: chain
    this will be the 3rd time its tightened this season
    You crazy bitch!!
    2003 sv650s copper!
  1. Chain
    Last Post: 06-01-15, 02:34 PM
  2. RK chain
    By MysteriousR1 in forum General Bike Related
    Last Post: 03-06-10, 09:39 PM
  3. Replies: 0
    Last Post: 05-03-07, 12:51 PM
    Last Post: 06-29-04, 12:23 AM
    Last Post: 05-28-03, 09:17 PM
