Results 1 to 12 of 12
Chain talk
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Chain talk
    I am in the process of picking out a chain and sprocket set and just realized how much I don't know about chains.
    Are there any advantages to buying a gold versus a non-gold chain?
    How much of this site is true?
    http://www.quality-cycle.com/truth_a...cle_chains.htm
    I like to think that at the end of the day most of the off the shelf chain and sprocket kits will work but being an engineer I want to get a feel for what is going on here. No sense in leaving anything to chance.
    Any personal experiences would also be good.
    TIA
    LRRS 878 Clapped out Gixxah
    Re: Chain talk
    i believe the gold is just for bling, and no actual performance gains. just make sure you get a rivet master link, if the chain comes with a clip on
    Re: Chain talk
    Quote Originally Posted by wiggeywackyo View Post
    TIA
    scanned through the article and it is correct as far as I know.
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: Chain talk
    go to a site that lists the tensile strengths...then buy one on a strength vs cost type scale
    LRRS #399
    MX #505
    Member madkaw's Avatar
    Nov 2006
    Pittston, PA
    Re: Chain talk
    Quote Originally Posted by DBKromz View Post
    www.sprocketcenter.com
    Raymond NH
    Re: Chain talk
    I replaced an OEM 25,000 mile EK with a low to mid-grade DID and only got 18,000 miles of use from it. The next chain, a high-grade EK lasted 28,000 miles. For me, the extra cost of the high-grade chain was worth it and I replaced the high grade EK with a high-grade Regina.
    NorthShore
    Re: Chain talk
    What kinda bike?
    Feb 2009
    City
    Re: Chain talk
    This will be on an F4i. From the looks of things, I should be able to skate by with anything over 8000lbs tensile.
    Anyone run a non-O-ring chain? Can you even buy those?
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    Re: Chain talk
    Yes, you can get non-o-ring, x ring, o-ring. 510 (?), 520, 530, etc.. A gaggle of different sprockets in just about any size and material.
    It comes down to your application and intended use. Aluminum sprockets and non o-ring chains are great for racing but, crap for touring, etc, etc, etc.. The variables are nearly endless.
    Pick your application and intended use and then go to a company you trust. They'll do the math and recommend a sprocket and chain set to match your needs.
    FYi - If you have a street bike or touring machine that you change the gearing on for different conditions, it's a good idea to have "sets". Sprockets and chain that have worn as a set rather than changing just the sprockets. Swapping out pieces in a set wears everything out quicker.
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
    Re: Chain talk
    Go with steel sprockets and and decent 530 rivet-type o-ring chain and be done with it.
    Re: Chain talk
    boston moto sells chains and rar sprockets. not sure if they sell front sprockets
    Infected Slyder's Avatar
    Concord, NH
    Re: Chain talk
    Quote Originally Posted by Butcher Bergs View Post
    Do the older 600's have 530 or 525 chains? I think they are 525 but I am not positive.
    EK X-Ring chains are great. If you go with an EK get the MVXZ. The 520 is 9300 lbs and the 525 and 530 are 9600 lbs.
  1. Talk me in or out of an RD 350
    By Spooler in forum General Bike Related
    Last Post: 05-20-15, 09:14 PM
  2. Replies: 0
    Last Post: 05-03-07, 12:51 PM
  3. Something different to talk about...
    By senecak19 in forum Pit Area
    Last Post: 02-14-07, 11:44 PM
    Last Post: 06-29-04, 12:23 AM
    Last Post: 05-28-03, 09:17 PM
