Results 1 to 13 of 13
Possibly Bent Swingarm
    Looking for a track bike
    Feb 2008
    Orange, MA
    I'm a newbie here at the forums so if this is the wrong place to post I apologize. I am in the market for a cheap track bike after putting my streetbike down at loudon last year. I was able to get my bike mechinally back together by last fall and took it out for about 2000 miles worth of riding. The bike moves, stops, and shifts fine however when I hit the corners something doesnt feel quite right...it may just be in my head because the bike has been put down...but is there a way to tell if something is bent?
    I put new forks on it that are straight, and I replaced the back rim as the original now has a substantial dent along the edge, which tells me the swingarm also took quite a shock. Oh yeah..the bike is a 2000 R1 if that helps.
    I have heard of a guy out towards boston that does frame measurements, but that sounds like it may get expensive. Any input would be helpful...thanks guys.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: Possibly Bent Swingarm
    yep, call Peter Kates from GMD....hes here on the board too. He'll tell you what your options are, its worth the $$.
    also, if it turns out that it actually is a messed up swingarm....you can get them cheap as shit on ebay. I'm not sure about R1's but swingarms for R6's go for like $50
    +1, talk to Pete.
    Smash it on the other side and it should bend everything back into place.
    Could be the swingarm bearings...
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Now that made me laugh
    Lifer Wishbone's Avatar
    Jul 2006
    That called "computree" and I think you need to get Pete's permision to use that technique
    I got a swing arm for a 02 fz1 for fiddy bucks on flea bay
    Lifer CMG241's Avatar
    Windham, NH
    Bring it to TTD in April, we'll all take turns on it and give you our honest opinions.
    and welcome to NESR
    Feb 2004
    Bellingham, MA
    Quote Originally Posted by robs400 View Post
    A measurement is $100 with out the bodywork, $150 with. I'll work an estimate of repair once I have the measurement, but the range is $25 for a wheel alignment to $1500 for a big smash. If you replaced the forks because they were bent you most likely bent the frame. I can fix frames, subframes and swing arms much cheaper than any rip off on Fleecebay. Also if you replaced the forks due to being bent you definately have bent triple clamps. (Both, not just one, you can't bend one with out bending the other) Again I'll let you know after the measurement. Call with any question.
    Feb 2008
    Orange, MA
    I'm not even sure if the forks were bent, the lower triple clamp definitely was so I just found a whole straight fork assembly with forks and clamps and put those on the bike.
    If I drive the bike down and remove the plastic, is this something that could be done in one day if scheduled ahead of time, or should I plan on leaving the bike there for a while?
    Feb 2004
    Bellingham, MA
    It's best to leave it.That way if I find some thing you don't need to make another trip to drop it off, and you won't be riding around on a bent bike any more than necessary.
    Jul 2006
    Just drop the bike off with your wallet stuffed in the frame
    Lifer BostonSVkid's Avatar
    Dec 2005
    Better to spend 100 for piece of mind then maybe that weird sensation when you go into the corner will go away if its straight.
    2006 Ducati Monster S2R800
    I'm tellin' you man....smash it on the other side.
    It's cheap and easy like _________________'s mom.
  1. Bent 09 R1 Forks
    By kmf in forum For Sale
    Last Post: 12-11-09, 11:41 AM
  2. Bent rim
    By Brit-Triple in forum Bike Maintenance
    Last Post: 05-31-08, 11:30 PM
  3. bent valve
    By RandyO in forum Bike Maintenance
    Last Post: 12-15-06, 10:39 AM
