Results 1 to 12 of 12
Tire pressure in cold weather
    Lifer SwiftTone's Avatar
    Norwood, MA
    Hey guys, as the temperature cools it's gotten me thinking about what tire pressure to use. I have Dunlop Q3+ that I've been happily running 34/36 on the street. It gave me plenty of grip and surprising mileage before the front had uneven wear and the rear was at the wear bar.
    Now the temperature has dropped, I'm thinking 34/36 will not allow the generate enough friction/heat to get traction.
    What are your thoughts on tire pressure in the cold to balance traction and longevity?
    Re: Tire pressure in cold weather
    Use the same pressures, just exchange the summer air for winter air.
    Take temps with an IR thermometer during a ride. See how warm they are getting. Only way to know for sure.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    I was thinking new tires if you are at the wear bars.
    Norwood, MA
    What am I looking for when I gather the cold/hot temperature variance ?
    Sent from my SM-G975U using Tapatalk
    Norwood, MA
    Yes, got new tires.
    Previous set I got 7400 miles on hypersport tires. Very impressed!
    Lifer golden chicken's Avatar
    Attleboro, MA
    I run the same pressures in cool weather, except I set them when the tire is warm rather than when the tire is cold.
    New Haven-ish, CT
    Is a drain and fill ok, or do I need to do a full flush?
    It's really best to flush them with spring air. You saved some, right?
    I generally drop pressure a psi or 2 in cold weather, but it ain't cold yet, day temps are still above freezing
    COLD AIR = FREE HORSE POWER
    Hiram, ME
    I've got some spring air in my R6 tires.
    It's from spring 2017, but still, spring air.
    I've been very happy with my Q3+ at 33F/37R (per my gauge), I don't change them when it gets colder, I just be more careful. Actually its probably time for new ones for me, but not until the spring.
    2013 ZX6R-636
  1. For Sale - Gear | cold weather gear
    By zgr in forum For Sale
    Last Post: 04-08-17, 09:44 PM
  2. Replies: 2
    Last Post: 09-10-12, 03:00 AM
  3. cold weather commuting
    Last Post: 11-05-11, 07:21 PM
  4. Cold Weather Gloves?
    By Fitz in forum General Bike Related
    Last Post: 03-26-08, 02:11 PM
