Page 6 of 6 FirstFirst 123456
Results 126 to 148 of 148
clutchless DOWNshifting
  1. #126
    Re: clutchless DOWNshifting
    I think it's just preference. I prefer less engine breaking. Leaned over downshifts smooth as butter allows later braking/higher entry speeds.
    Thanks I'm not sure if any of us have clicked 16's yet THIS year but I'm thinkin we'll all be ticking some off at the classic. Pretty sure 14's are straight up outta reach for an SV... Even for Ricky.
    ... back to your scheduled programming.
    I'm serious when I say that having a slipper will make it easier to run 16s every time you roll at Loudon. That would be a good goal. Better than a 14 or even 15s IMO. It will win you races.
    Oct 2005
    Wrentham MA
    I know this isn't a thread about slipper clutches per-se, but they're coming up enough that I had a quick question that may or may not warrant a separate thread:
    but if we have an adjustable one, is there a rule of thumb where more or less braking preferable for the track, or is it purely a matter of personal preference?
    I could see an advantage to either way, or even the possibility of preferring more engine braking on some tracks and less in others.
    Thoughts?
    just bang the downshifts wherever you do them without worrying about blipping the throttle or easing out the clutch.
    Graham
  4. #129
    Yeah I've had some thoughts about buying one, but $$$ is the restraining factor. I dumped enough cash into the chassis this winter that I don't have any fun money left to play with....... and if I did, I'd probably spend it on making my bike not look like crap so I could make it look like crap again later
  5. #130
    xxaarraa
    Guest
    Yeah I've had some thoughts about buying one, but $$$ is the restraining factor. ...
    Don't most bikes these days come with one? My last 3 bikes have. Isn't it the way of the world these days? Like traction control for superbikes, electric power steering and AWD for performance cars, HID lights for everything, etc. World has moved past non-slipper clutches it seems like.
    xxaarraa
    Guest
    Agree on preference. I suppose it also depends on what motor. On a V-twin, downshifting early and using the aggressive engine braking in leiu of hard braking for any particular corner, for instance, is a choice I have heard people make. I have never ridden an I-4, but I am told they don't have much engine braking at all? Same as 2 strokes?
    The slippers generally come with adjustable springs of different ratings, so Ductard, you can "tune" them to your preference and based on track too.
    SVs haven't moved past anything! lol.
    It's true that most new bikes have some slipper clutch tech. But the stock stuff is not the same as what we use for racing. Stock, they use fueling tricks to make the bike less prone to chattering on downshifts. There is generally still a lot of engine braking.
    The aftermarket clutches are ball and ramp style and the "release" a lot more than the stock types. The difference in feel is night and day! STM or Yoyodyne clutches are things of wonder. A lot less engine braking to allow aggressive and late downshifts that are butter smooth.
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Ducati 1299S. Clutchless up AND downshifting...I want one.
    xxaarraa
    Guest
    Wait 3 years. That's how long it takes Antonio to figure out how to make it right and iron out quirks. lol
    Lifer PhilB's Avatar
    Jan 2012
    Pittsfield, NH
    I ride mainly street; not much track (although I have done a few trackdays). I almost always use the clutch when shifting up or down, although it usually isn't a full squeeze; just a light squeeze to keep things smooth. I have practiced enough that I can shift well without using the clutch, both up and down, and that has come in handy a few times. For my bike, upshifting without the clutch is just preload the shift lever, snap the throttle closed for a moment to unload the gears and the shift happens, then throttle back on. Downshifting is even easier; just toe up the lever (I have reversed shift pattern on this bike), and the engine revs a bit between the gears and matches revs pretty well.
    It has come in handy when:
    Emergency acceleration is needed; it helps keep the drive going without interruption,
    Carrying a load where being able to use my left hand to keep everything positioned properly is nice,
    Riding for a couple hours in 30F weather and your left heated glove stops working,
    There is some sort of failure in the clutch actuation system.
    PhilB
  11. #136
    May 2011
    Northern MA
    ... I prefer less engine breaking...
    Well, there is something we can all agree on, except my mechanic for the repair money.
    I'm a huge engine breaking opponent.
    Unless it's Ricky. Then I'm okay with it, even though he's a super nice guy.
  13. #138
    I see what you guys did there...
    Lifer Pittenger5's Avatar
    Austin
    I could bang downshifts on my RMZ450 like it farted rainbows, but on my CBR600 I can't even get the damn thing in gear.
    Zip Tie Alley #505
  15. #140
    MotoGP: Rossi, Lorenzo debut seamless downshifts | MotoGP 0
    So it looks like up until RECENTLY even MotoGP riders used the clutch for downshifting and now use special gearboxes to do clutchless downshifts.
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    "MotoGP riders no longer need to use the clutch lever when downshifting, however this is unrelated to seamless technology."
    Not sure what the change was, but that suggests that at one point they did need to use the clutch. Not sure if the "unrelated" change happened a year ago...20 years ago....
    Either way, the whole idea of shifting by engaging 2 gears at the same time is crazy technology.
    LRRS 919
  17. #142
    KNEE DRAGGING BAGGER sedanman's Avatar
    Oct 2014
    Pawling NY
    My BMW touring bike has shift assist pro. It will do full throttle clutchless upshifts and closed ( or patiallly closed)throttle downshifts while it blips the throttle to match engine speed.
  18. #143
    That's what the article really says.
    That with the exception of Honda everyone else was using he clutch to downshift because it was upsetting the bike too much to do it clutchless.
    go faster cdovego's Avatar
    Weymouth
    Sav, OTT has video of Mat Mladin talking about clutchless up/downshifts from over 10 years ago.
    Right on the youtubes, google OTT and Mladin. 12 or 14 part series - great info.
    Central Mass Powersports #123
  20. #145
    Not 100% accurate. Everyone else was having to put more thought into it, but I'd bet they were still doing it clutchless. Just like everyone does clutchless upshifts now on bikes that don't have fancy electronics or seamless gearboxes. Sure, on paper we "can't" do them, and yet we do. If I can pull off clutchless downshifts on a chinese clash box in a pitbike smoothly, I guaran-damn-tee the MotoGP kit could do them better even before seamless gearboxes came back in vogue. (What's old is new again, 60's Hodoka anyone?)
    Clutchless downshifting can take a fair amount of practice to get right on each and every shift, you can get a system from flatshifter in the uk that has a self regulating engine vacuum powered clutchless downshift system, a lot of good feedback on the system on the net.
    Oh that setup ROCKS!
    Lifer GMAN226's Avatar
    Coventry RI
    with a slipper I used the clutch in a few corners but I would bang a few without the clutch too.. But that was a tractor motor in an SS so who knows if that applies to real motorcycles
    Gerard
  1. involuntary clutchless downshifting practice
    By brady in forum General Bike Related
    Last Post: 08-31-15, 12:21 PM
  2. Clutch use during downshifting
    By wiggeywackyo in forum Pit Area
    Last Post: 05-26-12, 07:53 AM
  3. I may have a downshifting problem
    By Duffy in forum Bike Maintenance
    Last Post: 10-26-09, 08:51 AM
  4. Downshifting after 520 conversion
    By redwinger in forum Bike Maintenance
    Last Post: 07-01-09, 10:05 PM
  5. downshifting while braking
    Last Post: 08-25-07, 12:39 AM
