Page 1 of 4 1234 LastLast
Results 1 to 25 of 98
urgent ! help needed in marlboro!
    43 mechanics st
    marlboro, ma
    Ray backed out of the trip for whatever reason and now:
    kcotter (keith) is stuck in marlboro with his girlfriend and 5 bikes bound for VIR.
    The trailer wiring is suspect and the lights dont work. Can anyone help out? 5 people are going to be very disappointed when their bikes
    cant get to VIR.
    keiths phone number is 802-779-4455
    Re: urgent ! help needed in marlboro!
    Thanks again Ray-Ray. Now it's MY problem. 8 people are now fucked because of you.
    You knew two days ago you werent going and you cant text me?
    need someone with basic wiring skill to fix the trailer.
    Jan 2009
    Waltham
    What exactly is wrong with it degs? No power to anything? What type of trailer?
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    I can get my son out there tomorrow, he's trained as an electrician, Though he doesn't work in the field anymore, he does help out with issues like this. I also have a bit of experience in the matter because I had a trailer that was prone to ground faults.
    Someone send me a PM with contact info and we'll be there with Fluke meters and tools. Is Keith the right person to call in the morning? I was confused because that's a Vermont number.
    Westford, MA
    I got a set of wire strippers, some 20 gauge wire, connectors, tape, and circuit tester.
    I have very little experience wiring though, but I can be there in an hour if needed.
    Jan 2009
    Waltham
    Quote Originally Posted by Rossco View Post
    What he said. And my flashlight holding skills are the f**king bomb.
    Sep 2011
    w. dover vermont
    Hey everyone thanks for the offers of help. Really shows what a great community this forum is. Ppl offering help at midnite on a Saturday is unreal. As of now it's under control. But myself and Derek are not the happiest people
    In the world.
    Lrrs/ccs expert #221
    Personally speaking, i dont think its in any control. I'm not sure why I'm responsible for this. Now its my responsibility?
    I say get help there and fix the wiring is a better option that us taking our trailer an hour north to go south again with a trailer with no lights.
    i say get help there asap or early morning. its a 12-13 hour drive. leaving at 10am is even ok.
    Pepperell, MA
    I'm up and 1/2 hour away. Not sure what I could do to help, but willing to try. I have tools/ will travel.
    Degs you should still have my #
    www.tailofthedragon.com
    Lifer golden chicken's Avatar
    Attleboro, MA
    i'm up. if it's standard 4-pin trailer wiring i could probably rewire the entire thing in 20 minutes. would need to make a quick pit at work for toolage.
    could probably be in marlboro before 1 if i left right now.
    Sep 2011
    w. dover vermont
    ok so matt will be there at 7am tomorrow to help get this shit straightened out. thanks everybody.
    Westford, MA
    Good luck man!
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    I can be there in the morning, I'm 10 minutes away in Hudson. I was a DC electrician for 8 years, I'll bring my gear, just send me an address.
    Nov 2010
    Warwick, RI
    Just saw the address at the top, I'll be there as well in the morning.
    Lancaster
    Wirelessly posted
    Degs you should have shot me a text. Coulda went over last night and took care of it.
    Corey
    675'r jtryz's Avatar
    May 2011
    Ashland
    if this is ever a food emergency, let me know
    May 2011
    Ashland
    Power of the internet. i hope u guys get fixed
    Sep 2011
    w. dover vermont
    this shit just gets better and better
    I am Dead now
    Oct 2009
    The tax State of the Nation
    So, is it fixed yet? If not I have the tools & supplies & I'm a electronics technician, I can repair it if you need me.
    Apr 2002
    Central MA
    OK, I'm up and can hop in the car if needed.
    If not, here's some tips:
    About 70% of trailer light problems relate to poor connections. The sockets in the connectors get corroded. The fix is to replace the connectors, but you can try scratching the corrosion off with a thin, sharp knife or similar, then fill the socket with dielectric grease. You should have the dielectric grease in the sockets anyhow, whether the sockets are corroded or not.
    Then there's about 25% of the time that a ground point has gotten broken or corroded. Pull the connection apart (usually just a sheet metal screw holding an eye terminal to the frame), wire-brush the eyelet terminal and frame clean, goop a little dielectric grease, reconnect.
    Only 5% of the time would the wiring itself have corrosion inside under the insulation to the point that it won;t carry current any longer, but it can happen.
    Those are the things to look for. I can be there in about 40 minutes with Fluke meter, wire brush, screwdrivers, te3rminals, soldering iron, and dielectric grease and other shit if you need me.
    My number is edited out
    Sep 2011
    w. dover vermont
    Fixed. Thanks jbmass golden chicken and everyone else
    Apr 2002
    Central MA
    Quote Originally Posted by k_cotter View Post
    And the problem was....??
    Lifer JohnnyV's Avatar
    Westborough, MA
    Wirelessly posted (Blackberry Tour)
    Quote Originally Posted by SprintPoser
    I think he mentioned the problem in the first post...
    Oh you mean with the trailer?
  1. Urgent! Sv650 rear brake caliper assembly needed asap!
    Last Post: 07-29-12, 11:48 AM
  2. Hi from Marlboro/Natick
    By DocCola in forum Welcome and Intro
    Last Post: 08-03-09, 09:07 AM
