Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Convert to GP Shift pattern :wavey:
    Newbie DZircher's Avatar
    Oct 2012
    Cambridge, MA
    Question Convert to GP Shift pattern :wavey:
    I would like to take the plunge and switch to GP (1 up / 5 down) shift patterns before next year.
    My current ride, Duc 848 EVO Corse, has a factory mounted power shifter.
    Convert to GP Shift pattern  :wavey:-wp_001456-jpg
    I'm not certain how to pull this off given the tight clearances in here. Does anyone know how to do this?
    Thanks,
    Dana
    Re: Convert to GP Shift pattern :wavey:
    That a quick shift sensor on the shift rod? It's likely a directional switch. If so, switching is gonna mess it up.
    Why do you want to switch? Just for a change? It doesn't really make things any better, faster or easier.
    Senior Member Dannyf's Avatar
    Middleboro, MA
    No can do with stock parts. You will loose DQS.
    "When there's a gap you either commit yourself as a professional racing driver that is designed to win races or you come second or you come third or come fifth, and I'm not designed to come third, fourth, or fifth. I race to win, and if you no longer go for a gap that exists, you're no longer a racing driver."
    Ayrton Senna
    Senior Member WinVT's Avatar
    Winooski VT
    I feel like a lot of people think they should change for some reason....my race bike is staying regular shift for next year.
    LRRS #313
    #331 CBR929RE's Avatar
    Bridgewater, MA
    GP is awesome. you're all stupid for not switching
    Westford, MA
    Theft deterrent.
    ...I have your pants!!!
    Banned G21forme's Avatar
    Lakes
    Check with gilles because they make the some great stuff.
    i have vortex rear sets and have GP shift. i love it. hard exceleration is easier, and clutchless shifting is easier. dont know about switching your ducati, but i would imagine aftermarket rearsets would allow it.
    Oct 2012
    Cambridge, MA
    It looks like Woodcraft has a set that works either shift pattern.
    I'll hook the component coming off the shift linkage to my scope/vom and see what it's doing in action. Could be a switch, it could also be a stress gauge (variable resistance). Either way, I'll update this thread with what I learn. If anyone already knows the electrical characteristics of this parts, let me know.
    -Diz
    Oct 2012
    Cambridge, MA
    A normally opened micro momentary switch. This is interesting because it would appear that the switch doesn't close until considerable travel has occurred in the linkage. Given this simple trigger, I would imagine that a similar switch could be engineered for a different travel direction.
    Derry NH
    Other companies make quick shift switches for either push or pull, Dynojet for example, so you can set up their quick shift on any bike no matter the linkage setup. If you want to switch it, you'll either have to get rearsets that allow it, or you may be able to change the sensor out and reposition some linkage to get GP shift.
    Lifer union's Avatar
    Blackstone, MA
    Wrong. Gilles is garbage. Lets start with their support is awful. If you need a peg because of a crash youll be waiting. At the shop we had stuff (one peg) on back order for like 8 months. When it finally came in it took us a while to find the guy that wanted it. Second I dont know what they make their stuff out of but its about as hard as warm butter. You might as well just toss all the bolts that come with their stuff right in the trash and go out and buy some new ones. Youll be able to tighten them one time. If you want to adjust the position of the peg and you did use the hardware that came with the kit get some bolt extractors. I had a set. Also stay away from their chain adjusters/bike lift stuff. Same problem. Way too soft. Ive seen too many failures.
    Quote Originally Posted by WinVT View Post
    I find it much easier to upshift when leaned over with gp shift. Most useful exiting 3 and coming over the hill and then exiting the bowl.
    James
    Lakes
    Quote Originally Posted by DZircher View Post
    or possibly a switch of a wire or 2
    Lakes
    The bolts are junk I agree but I've crashed on both sides and watched an old r6 crash hard on them with just minor grinding on the pegs. However the op was looking for gp shift options and gilles has some amazing solutions for making bikes gp shift that other manufactures say is impossible. Is he racing this machine?
    Quote Originally Posted by Rossco View Post
    Theft deterrent.
    more than once, I offered to let friends that wanted to try out an SV, the opportunity ride my SV, when I informed them it was GP shift, they changed their mind
    I switched only cause theres one increasing radius corner near my house that you couldn't shift easily coming out of the corner with conventional while still leaned over
    Lakes
    Confused, how would conventional shift be easier? And I'm assuming you meant decreasing radius.
    you read that wrong. he said its harder to shift while leaned over with conventional.
    my room mate had GP on his SV while i still maintained regular shift. on one track there was a corner that would beneficial to be able to upshift but it was hard with REG shift but it was easy with GP. 2 corners prior to that though a downshift is needed so REG had the advantage over GP there
    Wirelessly posted
    Quote Originally Posted by SVRACER01
    I'm trying to imagine a scenario where a downshift would be needed in a corner.
    Enlighten me.
    Blackstone, MA
    Wirelessly posted
    Enlighten me.
    When you feel like crashing.
    James
    there was a corner at firebird was similar to the 12 chicane but the other way. accelerate hard down the back "straight", start turning left (like the entry to 11), on the brakes hard, then flick right. you had to grab a downshift so you would have some GO at the apex of the right hander. gas it for a long opening left that required an upshift midway through.
    Wirelessly posted
    Enlighten me.
    especially leaned over enuf that ya wouldn't be able to get yer toe under the shifter
    Enlighten me.
    Somethin like turn 11.
    youve been riding long enough randy to know that you dont have to be leaned over that far to drag a toe which is essentially what we are talking about here
    Wirelessly posted
    You should be clicking the downshift when you're flipping.
    Lakes
    You can grab a downshift while flicking into 11A. My slow ass and the way my bike is geared works pretty good.
  1. For Sale - Parts & Tools | 06-07 Yamaha R6 Bazazz QS4 GP Shift Pattern
    By Jason P. in forum For Sale
    Last Post: 07-25-14, 01:53 PM
  2. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  3. Aprilia RRV (SXV convert)
    By typeone in forum Pit Area
    Last Post: 02-25-10, 12:18 PM
  4. Replies: 10
    Last Post: 12-03-07, 06:25 PM
