Re: Count Down Untill 2013 Season Kicks Off!
Quote:
Originally Posted by
csmutty
He didn't send them out to paint haha.
He rattlecanned them today with a hf can sprayer attachment in his garage lol.
tsorfas
I paint them myself that's what iv been doing today all day
Either way Id rather try and mount them up first. This way you can fix anything you need to from mounting and drilling before you paint. I have yet to find a set of bodywork that just fit right up without some sort of modification. At least tell me you didnt just go and drill holes where they suggested.
It had already some holes. I bought them from Gino.
I will need to make some modifications for sure for the frame sliders to come through and something to hold the lower fairing more secure. Wanna help??? :-)
tsorfas
Where are you and when? If preteen is going it might be incentive enough.
Haha Worcester MA around 3-4pm to start? Or maybe even later..
Not to far away from me. About 20 min but weekdays dont work for me. I have a crazy ass dog and work second shift.
I could be over there saturday evening Sav. Is your bike drilled for wire yet?
The things I KNOW have to be drilled yes they are. The bike has been raced previously (I think) so it should be. However surprised might occurre but we will have a full automotive garage available to us with plenty of tools to do whatever we have to do :-)
Oh and you bringing the wire for me right? Haha. And maybe your plyers? Unless my $6 hf ones will do it?
csmutty
If you're thinking of riding over after we leave Westfield, I might tag along.
Saturday is possible. Ill have to see where Im at near the end of the week.
This is looking promising! Thanks guys :-)
Mr. Kurtz
Now it's a fucking party!
Mr. Kurtz
I actually won't be in Westfield Saturday because I am teaching a MSF class. I am only going to be able to make it on Sunday. But you can come hang out at Sav's.
And Sav your pliers will be fine. I have basically the same ones but I bought them from PU. I will order the wire tomorrow. Should have it in sometime this week.
csmutty
Damn clarkie! Someone has a program!
Ya buddy!!!!!!!!!!!!!
Few loose ends to deal with and I am all set
Larry
Check that your expansion tank has air on the correct side of the bladder before you go pulling the pump. I have never known a pump to be the cause of water hammer. It is almost always a leaking expansion tank bladder.
I drained the tank of water, it holds pressure, air that comes out of the bladder is dry with no odor. I've got a professional plumber coming Tuesday to help diag. What I can see at the moment is once the pump shuts off, the water level is dropping in the supply line, drawing a vacuum. When the pump comes on, there is a good 4 to 5 second delay before the water reaches the in house check valve. If the pressure tank has water in it (system is at cut-in pressure, 38psi or so) when it hits I get a single hammer at the 'T'. Then it fills as normal till hitting the cutout at around 58psi. I'm thinking it's gotta either be the check valve in the pump or I've got a leak in the pipe between the pump and the house.
csmutty
Annnnd, I forgot, going out in Hartford that night. You guys should wire fast, then come down and hang out.
Mr. Kurtz
This plan is even better lol
Payment is you are buying then Sav ;)
PS...just ordered your safety wire this morning bud.
ok so $20 for drinks for you and $350 for me
Kurlon
I have a spare 1" NPT check valve if you want to throw it in and try it. You can at least eliminate one check from the system.
tsorfas
That's Jay-Z ticket money you're throwing around on drinks!
Finally got the bike up to Mark for carb magic. Only mechanicals left are new clutch plates, spark plugs, and a dyno run.
Larry
Why do you have spare check valves kicking around? :D I actually put a new one in this weekend, no change in behavior. That's when I decided it was time to have a pro come and check my work 'cause from here if I did everything right it gets expensive. I'm kinda hoping he finds a mistake on my part.
24 Days fuuuuuuuuuuuuuuuuuucccccccccccccccccccckkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk kkk
Holy shit this is happening
