Results 1 to 4 of 4
Street Triple Shock Spring Swap
    Jun 2012
    Westborough
    I weigh 157 lbs without gear.
    For a Street Triple 2010 R, Race Tech recommends the following
    FRONT FORK SPRINGS
    Recommended Fork Spring Rate: 0.788 kg/mm (use closest available) - 0.85 available
    Stock Fork Spring Rate: 0.9 kg/mm(stock)
    REAR SHOCK SPRINGS
    Recommended Shock Spring Rate: 11.425 kg/mm (use closest available) -11.6 available
    Stock Shock Spring Rate: 12.6 kg/mm (stock)
    Is it worth the upgrade ?
    As an alternative would backing off pre-load help?
    Re: Street Triple Shock Spring Swap
    Depends on the use of the bike really. Do you have any issues with it as is?
    Jun 2012
    Westborough
    suspension seems harsh on smaller bumps. I keep my hands real loose at all times but there are times I feel like the bumps might be causing me to change throttle input.
    Yes, the suspension on these is a bit harsh. Softening the spring will help, but you could try taking out a LITLLE pre-load, and compression damping first.
  1. For Sale - Parts & Tools | Triumph Service Manual (Daytona 675, Street Triple, Street Triple R)
    By GoSlow2GoFast in forum For Sale
    Last Post: 06-03-20, 04:47 PM
  2. Wanted - Parts & Tools | SHOCK SPRING
    By smokinjoe in forum Wanted
    Last Post: 06-03-19, 07:11 AM
  3. For Sale - Motorcycles | 2006 Triumph Speed Triple (trade for a street triple)
    By norco4hun in forum For Sale
    Last Post: 04-26-14, 07:49 PM
  4. Couple of pics from today: Speed Triple & Street Triple
    By Talus in forum General Bike Related
    Last Post: 05-05-11, 09:26 PM
  5. Finished: Triumph Street Triple 955i into Sprint RS engine swap!
    By KingCast 650R in forum General Bike Related
    Last Post: 03-19-11, 11:35 AM
