Results 1 to 14 of 14
Custom radiator stay
    My FZR needs a lower radiator stay to keep it off the exhaust. I've got an idea in my head, and can bend up an ugly option using Home Despot slag from the hardware isle, but I'd prefer something lighter, less mad max and more OEM looking if I can achieve it. Any good resources on the forum for something like this?
    Natick
    Wirelessly posted
    You can't find an oem part for it? Then is imagine the only other thing than home depot is custom fab...
    Re: Custom radiator stay
    The bike was never imported to the US officially, and the motor may or may not resemble OEM specs now and hence has a different radiator than what shipped with the bike...
    Custom is my only option. A 'T' made out of aluminum tube to the right dimensions, with a tab on the radiator end to accept an isolation bushing where it bolts to the rad would be perfect. I suppose if I was being extra cute I could further isolate it by using press in well nuts instead of threading the aluminum.
    Damnit, I need to learn to weld and assemble a proper machine shop.
    Natick
    Wirelessly posted
    Ooh, that would make sense...sorry, I don't really know anyone that could make custom parts....I dream of it, and have been to places that have die casting and other fancy things, but they would never do little parts since it really wouldn't be allowed.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    I could use a similar service since the cheapo Ace hardware exhaust strap brackets I made to hold my exhaust to the subframe didn't last the whole race weekend.
    You are kurlon. Anything is possible.
    Haverhill, MA
    Tricky Mike?????
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    aluminum "L-channel", cut and bend at will, tack it - then have a good tig guy finish it up.
    lightweight, strength. I have some lengths of this aluminum but am nowhere near you... Got them at fastenal on the cheap.
    Good suggestion Kitt, I think I pull that off in the Lab easily enough, then find a friend to finish weld it.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    http://www.123dapp.com/
    Model what you need.
    Have it printed in a material you like.
    I... think I'll stick with trying to fab something local, last time I modeled something up for fun the resulting cost for a one off job was stupid crazy. I think I was at $800 for a single fork tree for my mini with no cosmetics.
    http://www.tractorsupply.com/hobart-...k-of-8-3851303
    Anyone played with aluminum braising? I have a torch... I could in theory do this myself with this stuff.
    Lake Champlain, VT
    tack and tig
    Lifer Trouble's Avatar
    Monkton, VT
    It can be finicky but I've had decent luck. Made my belly pan using light gauge aluminum and braised it. I've found that heavier gauge aluminum is easier to work with. Lighter material seems to melt before the braising rod unless you time it just right. If you do it just right you can weld aluminum cans together but it takes a lot of patience. This was a boring winter evening:
    LRRS EX #7
    Low Down Racing
    Providence,RI
    Pop rivets would also work if you don't have a welder to tack it.
  1. Replies: 12
    Last Post: 10-18-12, 09:39 PM
  2. wtb radiator f4i
    By crowspeed07 in forum Wanted
    Last Post: 08-12-10, 05:22 PM
  3. 2001 CBR 929RR Single Sided Swingarm, custom custom custom
    By customfighterer in forum For Sale
    Last Post: 06-29-10, 02:03 PM
  4. WTB: Radiator for 2nd Gen R6 (03-05)
    By RyanNicholson in forum For Sale
    Last Post: 07-25-08, 08:00 AM
  5. Radiator.........
    By tatersalad in forum Bike Maintenance
    Last Post: 06-06-07, 07:20 AM
