Results 1 to 8 of 8
Day before track day and my throttle sticks
    Giddy up! joberly's Avatar
    Apr 2004
    Raynham, MA
    Wonderful... just noticed it today.... so, anyone staying at the red roof inn that works for beer?
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    Check to see if the grip is up against the bar weight. I've seen most throttle stick problems there...
    Jim
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    Lifer ZX-12R's Avatar
    Candia, NH
    First check rice-rocket's suggestion.
    Next trace the cable and make sure it isn't binding up anywhere.
    If it's not that, run to the store and get a can of WD40. Unhook your cables and spray some down into them and pull the cable back and forth until it loosens up.
    If that doesn't work and you have dual throttle cables, unhook one and see if it still sticks. If it does, switch to the other one.
    Last but not least, see if you can find a spring at a hardware store and hook it up to your carbs or throttle bodies to supplement the factory return spring.
    Mt throttle was a little sluggish when I was giving the bike a once over and prepping it a few days ago. I unscrewed the right throttle/electrical housing and sprayed some white lithium grease down into the cables. I twisted the throttle a couple times to work it down into the cable and now it snaps shut like a mouse trap
    Lifer bbhzx10's Avatar
    Jul 2004
    North shore
    We'll be at thr Red roof Wed. night, hope you have it fixed by then, but if not we can take a peek!
    2001 Silver ZX-12R... RIP
    2005 KDX 200
    Apr 2004
    Raynham, MA
    Thanks guys, I'll take a look at those suggestions before heading up today! Thanks for the offer bbhzx12, I'll be pullin the red F2... now it's time for work... yes at 2am
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    FYI
    I know this from industrial machinery
    WD-40 dries out leaves a slight sticky fillm that eventually attracts dirt etc.
    Marvel mystery oil never dries and leaves no sticky film
    Also lube between bar and roller grip
    Sticky throttle would improve lap times
    Glen Beck is John the Baptist
    Possible causes of sticky throttle:
    1 - Rubber grip is sticking to bar or against housing that has the starter button.
    2 - Cables are dirty or sticking
    3 - Cables are pinched (usually after removing tank)
    One thing that NEVER causes a sticking throttle is the throttle tube sticking to the bar. DO NOT lubricate this area as it will simply attract dirt.
    A plastic throttle tube will NEVER stick to a METAL bar assuming both parts are in good condition. Lubrication between these parts might temporarily mask the problem, but it will never solve the problem.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
  1. Carb sticks or similar help needed
    By SprintPoser in forum Bike Maintenance
    Last Post: 05-10-17, 11:18 AM
  2. 07 CBR600RR Coil Sticks
    By Kurlon in forum Wanted
    Last Post: 06-01-12, 01:30 AM
  3. Greatings from a town in the sticks with alot of hicks.
    By 9secondsflat in forum Welcome and Intro
    Last Post: 10-18-11, 07:37 AM
  4. Wanted: Sticks of older laptop memory
    By schleppy in forum For Sale
    Last Post: 12-22-08, 11:43 AM
