Friend sent me this link. Curious if it's a good deal or not... I need new skins.
http://www.tireexpress.com/prod.cfm/cid/9000/pid/11537
$239 shipped for 180, $259 for 190.
That's a good deal.
These would be for street. So... seems like a good deal. Might have to pull the trigger.
Thanks guys.
Street tires? Not doggin' your choice, but:
"Rubber compounds developed through Moto GP racing require minimal warm up time
The softest rubber mix in its class for remarkable grip and maintains performance even at advanced stages of wear
Unprecedented lean angles 50.6 degrees dry and 41.9 in the wet
Rubber mix remains tacky even at low temperatures
Grooved area is less than 12% of tire area for phenomenal cornering adhesion"
On the street, these ain't gonna last too long, are they?
Was about to pull the trigger until I read this. Now I'm going to hafta sleep on it.
http://www.canyonchasers.net/reviews...ilot-power.php
Tire Express and American Moto Tire seem to consistently have the lowest prices; they tend to alternate back and forth a bit depending on the type of tire. I've ordered from both.
Can't advise you on the tires though. If you were buying dual-sport tires I could talk your ear off, but I don't even own a bike that I could put Pilot Powers on.
--mark
I only have 4k miles on my set. They are starting to have a little flat spot in the back. I fear I only will get another 1500 miles out of them. They are junk! Wah!
(sarcasm)
I got 7000+ on my PPs, with 6 trackdays on them too. I gave them to a co-worker, and they still weren't on the wear bars. I replaced them with 2CTs, only because I was a little concerned about heat cycling on the track. They were probably fine though. I was probably being overly cautious.
Mind you, they were mounted on an 86 GSXR. Your mileage may vary!
