Results 1 to 12 of 12
Degsy
    .... naked-daytrader's Avatar
    May 2007
    Degsy
    Ducati tech called me today. He's replacing the starter moter, the alternator and the ECU. Said the alternater putting out to much juice which hit the battery. Also said I would make out because he ordered me the performance ECU. Thing is I have a stock pipe still on the bike, Is this guy blowing smoke up my ass? I know the performance ECU has a more agressive fuel/spark/timing map, wouldn't it screw up the bike more by leaving a stock pipe on? I'm confused I know the upgraded ECU will save me some money if I decide to throw an aftermarket exhaust on (besides Termi's which come with the peformance ECU's). Any comments?
    CCS|LRRS EX#49
    2006 KTM 560 SMR - 2006 Yamaha R6
    LRRS Rookie of the Year 2002-2006
    Apr 2006
    Beverly, MA
    Degsy
    I'd give Ducati a call and ask them. Maybe if you sound concerned enough they'll send you some Termis
    .... duey's Avatar
    Wilmington MA
    Degsy
    at my job we had a customer come in with a 1098s that had the full termi system and he was hell bent on blaming the termi pipes, for the stalling issues. So per his request we installed his stock pipes (kept term ecu as he didn't have original one). And he barely made it out of boston before coming back to get his termi pipes put back on.
    Now this is the only 1098 i've ever seen run ecu only, so it could be an isolated issue.
    2021 Ducati Panigale V2
    2020 Honda Grom
    Nov 2004
    Boston, MA
    Degsy
    The perf ECU is probably just the replacement ECU that ducati is using on the bikes with the stalling/starting issue. It is being replaced quite regularly on 1098's.
    I'd post this on ducati.ms or 1098-forums for an answer from about 500 people with stalling/idle/starting problems with the 1098. Many have had the ECU repaced, but not many needed the alternator/starter. Most have resolved the problems from what I have read.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Degsy
    Good to know that after all these years, Ducati's electrics are still shit.
    Nov 2004
    Boston, MA
    Degsy
    Quote Originally Posted by rebelpacket View Post
    As I understand it (and I don't all that well) it is a set up issue. The dealers are not setting up the fuel/air/idle/bullshit up right which is causing stalling at idle. I have heard (and I dont know if it is true) that some dealers have had zero stalling problems and some have had lots and lots.
    I believe the ECU issue has to do with allowing the bike to restart after multiple stalls and not the stalling itself. Again, this is all from crap Ive read on the duc boards.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Degsy
    Quote Originally Posted by naked-daytrader View Post
    Alternator didn't cause the battery issue. It's very likely the battery issue (loose terminal) damaged the alternator though.
    As for the ECU, if it is the performance ECU, I believe you will still get an advantage as it will not be tuned for EPA regs. Should take care of any flat spots. As Manny says, it is probably a Ducati recommendation for any bikes with stalling issues.
    Derek
    May 2007
    Degsy
    degs, thanks.....
    CCS|LRRS EX#49
    May 2007
    Degsy
    Sorry pal................" Thanks Kurt"! Actually thanks for having an allen wrench in your tool kit...ha. How firm are you on the June 30th ride? I mean is it set in stone? Saturdays just don't work for me. Check my PM on grouprider. I could try to get the day off if need be but didn't know how set June 30th was.
    CCS|LRRS EX#49
    May 2007
    Degsy
    Quote Originally Posted by 04ZRX View Post
    Hey Mark, I said almost the same thing... What about me?
    I'll be glad when it is fixed & you & I can ride together.
    Later, Bud
    Also Kurt I was actually more curious about the performance ECU issue. Just didn't know if it would work with a stock exhaust.
    CCS|LRRS EX#49
    May 2007
    Kurt one more thing
    I was coming back from work the other day and decided to take the long way home from Wellesley Hills. I found a kick-ass set of twisties leaving Natick heading into Medfield wand probably passing through another town. It's a good 20 minutes long. Definetly gotta check it out. It's about 8 minutes away from the center of walpole.
    CCS|LRRS EX#49
    May 2007
    Degsy
    I missed that part of your RFI (request for information) from Degsy. Is your Ducati fuel injected or carburated? if it is "FI" I would spend a few bucks and get a Power Commander for it.
    It's fuel injected and they don't make the power commanders yet for them. A performance /race ECU (which he's supposedly installing on my bike) is the same as a power commander I'm told, however the performance ECU can only be mapped by computer (not sure about the power commander).
    CCS|LRRS EX#49
  1. Degsy.....
    By Jaynnus in forum General Bike Related
    Last Post: 05-22-08, 07:41 AM
  2. Thanks Degsy!
    By TLRMan in forum Bike Maintenance
    Last Post: 04-03-08, 09:16 AM
  3. Hey Degsy!
    By Jank in forum General Bike Related
    Last Post: 10-12-07, 09:08 AM
  4. Degsy is the man.
    By LuvDog in forum General Bike Related
    Last Post: 05-14-06, 01:54 PM
  5. Thanks Degsy !
    By PinHead in forum Pit Area
    Last Post: 09-02-03, 03:18 PM
