Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
Doc's new toy
    Lifer Pittenger5's Avatar
    Austin
    Re: Doc's new toy
    Id ride it in Boston, like those tools that hit the stop sign on Newbury
    Zip Tie Alley #505
    Re: Doc's new toy
    those were not tools, that was greatness13 year olds on stolen chinese dirtbike rolling up newbury
    the coolest i had seen in a while
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Re: Doc's new toy
    Cool, so first things first, replace the front end with an NSR50 setup, that way both fork legs can do something of value. Next is a rear shock-ectomy, again putting in something that has damping. Douglas Wheels makes nice wide rims so you can mount proper rubber.
    For the motor, I suggest binning it. There is a bracket kit that will let you mount an XR100 motor in it's place. That would be too easy though, so start with an XR80 instead (same mounts) which nets you a lighter crank and closer ratio gearbox. Put a nice 115 kit on it, consder replacing the head with a larger valve import unit, a 24mm flat slide carb, and now we're talking fun.
    There is an alternate bracket kit that will let you mount a motor like I run in my 70. 151cc, 16+ HP, enough gumption to crack 90mph... : )
    im listening.... my YSR motor went my G/F really wants a 4 stroke motor.
    would one of those Lifan motors fit?
    Re: Doc's new toy
    With the adapter bracket, it's basically a bolt in job to mount a Honda 50 style motor, so Lifans will work, Jialings, YX Motorsports, lots of options. I'll dig up links later.
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Doc's new toy
    I am also intrested in the links.
    Re: Doc's new toy
    You selling?
    crap they have been sitting in my friends house for so long the price will be cheap. the old one i had year ago the kick start was busted so i had to push it and drop it into second gear. so fun to do after a few drinks
    Jericho, VT
    Re: Doc's new toy
    Quote Originally Posted by weman View Post
    I will happily take them off your hands. Let me know please. Buying soon.
    bye suzuki, hello world! xbubbax's Avatar
    hudson MA
    Re: Doc's new toy
    lemme guess....CL?
    i saw that bike on there....i almost scooped it up
    Jericho, VT
    Re: Doc's new toy
    Yep...
    Re: Doc's new toy
    how much do those brackets run?
    Re: Doc's new toy
    No idea, although it'd be just as easy to make a bracket or mod the frame directly for xr50 or xr100 style motors if you've got access to someone who can weld.
    Re: Doc's new toy
    i wish.
    itd be easier to buy it.
    Jericho, VT
    Re: Doc's new toy
    I am gonna look into it too Oxx. Let me know what you find out.
    Or I have that spare motor...
    Re: Doc's new toy
    Call up the crew at Cycles128, one of their regulars has done an XR100 conversion and can likely point out cost/sources/etc.
    Jericho, VT
    Re: Doc's new toy
    I'll just email the guy when I get home and can access myspace.
    hudson MA
    Re: Doc's new toy
    hows it run>?
    is it hard to start?
    any pors and cons about owning one matenance wise?
    Jericho, VT
    Re: Doc's new toy
    Yep it runs, It is an easy kick start, Maintenance appears easy and CHEAP.
    Re: Doc's new toy
    Kurlon,
    that bracket is for a horizontal motor. is there one for a vertical motor or is that all custom shit?
    id like to get a Lifan 200 in there or something similar. more power, more gears, more speed. i really want to ride it on the street without worrying that ill hold people up.
    Re: Doc's new toy
    All I can find at this point are one off custom jobs.
    I Void Warranties LowSider's Avatar
    Jul 2005
    Re: Doc's new toy
    I took that thing for a spin last weekend at the track and had a ball on it. I had so much fun on all of the pit bikes I borrowed and tooled around on. The mini pit bike race was the best.
    Jericho, VT
    Re: Doc's new toy
    I am gonna start charging for rides on my YSR.
    She was like a lil bitch in heat with all the attention she got.
