Results 1 to 16 of 16
Motion pro chain tool
    TWINS! xrocket21's Avatar
    Central Maine
    I broke pins on my motion pro chain tool, they are shown as 290 and 380 in the case. Online all I can find is 3mm and 4mm. WTF?
    Re: Motion pro chain tool
    sounds like they're saying 0.290cm or 3mm, and 0.380cm or 4mm
    Central Maine
    Thanks, I ordered the 3mm and 4mm
    I tried converting .290" to mm and it wasnt even close. Never considered cm.
    millimetre is easier to use, but it sounds like they're just rounding up to make things more simple. why they would use both numbers is strange.
    Central Maine
    Motion pro chain tool-20200716_160148-jpg
    Nov 2009
    Bristol County
    I have the Cyclegear/Stockton knock-off of the same kit and it lists the pins at 2.2mm, 2.9mm, and 3.8mm for cam chain, 420 chain, and 428 thru 630 chains.
    P/N for the 3.8mm breaker pin is 422238
    I suspect it's a 4mm hole that the 3.8mm pin is for.
    nedirtriders.com
    As someone who grew up correctly (i.e., with the metric system) the notion of using centimeters to measure something <1cm is stupid. That's why we have mm, for fuck's sake. Be better.
    Thank you for coming to my TED Talk.
    Nov 2009
    Bristol County
    I really don't know why we haven't switched. Please continue with the TED talks.
    But in this case, from the photo above, it looks a lot like there is a very small 'dot' of plastic after each initial digit. I could see how they get missed though.
    nedirtriders.com
    I no longer need Ted talks now that I have found "Randy buys a bookshelf off Gumtree". Australia has settled it's "supplying comedy to the rest of the world" debt with Randy.
    I've never heard of him until now.
    That was 20 of the funniest minutes of my life.
    i've had some recent discussions with them and their engineers on a kit i bought that wasnt designed/advertised properly.
    why they didnt just round up and say 3mm, 4mm, 5mm is just strange. maybe someone took them to court saying it wasnt accurate or something.
    This is K and N all over again, isnt it?
    Tip for not breaking pins. Grind the rivet flat before you press, amateurs. :-)
    that was my fault for not tightening the filters enough. ever since then, i torque them to 16.5 ft/lbs per spec. never an issue since.
    i dont break my pins. i did have one get messed up from a novice borrowing my tool though. cross threaded the tools and everything.
    Haha, yeah. the grinding comment was not meant for you. I know you do that. I saw the gixxer yesterday at alex's. Motor sounds nice. no ticks.
    Chain tools are on my "never lend" list.
    removing the tank off is a PITA, but man it's clean under there. got all new clips to secure and route things properly. did tap & die on most of the bolts, then greased/antiseized them before torquing them. it's got a solid foundation.
  1. For Sale - Parts & Tools | Motion Pro Chain Tool *link*
    By xrocket21 in forum For Sale
    Last Post: 08-14-20, 05:58 PM
  2. Motion Pro Carb Sync tool
    By bogie413 in forum For Sale
    Last Post: 05-27-13, 11:31 AM
  3. Motion Pro chain breakers
    By Rada in forum Bike Maintenance
    Last Post: 03-18-12, 12:05 PM
  4. motion pro chain tool on sale - $69
    By gamorg02 in forum Bike Maintenance
    Last Post: 09-15-11, 03:48 PM
  5. Replies: 0
    Last Post: 06-05-11, 12:47 PM
