I broke pins on my motion pro chain tool, they are shown as 290 and 380 in the case. Online all I can find is 3mm and 4mm. WTF?
I have the Cyclegear/Stockton knock-off of the same kit and it lists the pins at 2.2mm, 2.9mm, and 3.8mm for cam chain, 420 chain, and 428 thru 630 chains.
P/N for the 3.8mm breaker pin is 422238
I suspect it's a 4mm hole that the 3.8mm pin is for.
nedirtriders.com
nedirtriders.com
that was my fault for not tightening the filters enough. ever since then, i torque them to 16.5 ft/lbs per spec. never an issue since.
i dont break my pins. i did have one get messed up from a novice borrowing my tool though. cross threaded the tools and everything.
