Results 1 to 17 of 17
Using a quick shifter - Helpful
    Member THE STUFF 187's Avatar
    SWANSEA MA
    I have installed many quickshifters & one to many times have had issues with the shift rod not having the correct amount of adjustment needed for the best shifter to foot position & have seen many people move the splinded joint on the shift shaft, which can cause hard, clunky, limited gear engagement while shifting & damage to the transmission. Thought this might be helpful given it tells you how many sections you my need to be cut from the shifting rod using non oem rearsets.
    Justin@Adrenaline Cycle
    Dynojet Power Commander Shift Rod Kits. The Dynojet Shift Rods are designed for certain Quick Shifters and work only for specific bike models and setups. As a result, not all bike models require the purchase of a Shift Rod Kit.
    How to Find your Bike's Shift Rod
    To determine whether or not your motorcycle requires a shift rod kit, please refer to the information below (NOTE: You can also use these shift rod build kits for universal applications). The chart below outlines what type of Dynojet Quick Shifter your bike uses and what shift rods will be needed with the stock rearsets and the standard shift patter. For racing shift patterns (reverse shifting), you will need to determine if you are pushing or pulling the shift rod end points so you will select the correct setup. If you have any questions do not hesitate to contact Adrenaline cycle 508-379-0100.
    Models Using the PC5 require the use of the QEM add-on unit.
    Aprilia•RSV Mille 04-08 :LINEAR PUSH Type
    Tuono 03-05 :LINEAR PUSH Type
    Ducati•749 03-06 :LINEAR PUSH Type
    848 2008 USH Type One 1 Shift Rod A (remove/cut off 6 sections)
    999 03-06 :LINEAR PUSH Type
    1098 07-08 USH Type One 1 Shift Rod A (remove/cut off 6 sections)
    1098R 2008 USH Type One 1 Shift Rod A (remove/cut off 6 sections)
    1198 2009 USH Type
    Honda•CBR 600rr F4i 01-06 USH Type One (1) Shift Rod B
    CBR 600rr 03-04 USH Type One 1 Shift Rod A
    CBR 600rr 05-06 USH Type One 1 Shift Rod A
    CBR 600rr 07-08 USH Type One 1 Shift Rod A
    CBR 600rr 09-10 USH Type One 1 Shift Rod A
    CBR 929rr 00-01 USH Type One 1 Shift Rod A
    CBR 954rr 02-03 USH Type One 1 Shift Rod A
    RC51 00-01 :LINEAR PUSH Type
    RC51 02-06 :LINEAR PUSH Type
    CBR 1000rr 04-05 USH Type One 1 Shift Rod A (remove/cut off 1 section)
    CBR 1000rr 06-07 USH Type One 1 Shift Rod A (remove/cut off 1 section)
    CBR 1000rr 2008 USH Type One 1 Shift Rod A + One (1) Shift Rod C
    CBR 1000rr 09-10 USH Type One 1 Shift Rod A + One (1) Shift Rod C
    Kawasaki•ZX-6r 03-04 USH Type One (1) Shift Rod A
    ZX-6r 05-06 USH Type One 1 Shift Rod A (remove/cut off 6 sections)
    ZX-6RR 2003 USH Type One 1 Shift Rod A
    ZX-6RR 2004 USH Type One 1 Shift Rod A
    ZX-6RR 05-06 USH Type One 1 Shift Rod A (remove/cut off 6 sections)
    ZX-6r 07-08 USH Type One 1 Shift Rod A (remove/cut off 6 sections)
    ZX-6r 09-10 USH Type One 1 Shift Rod A
    EX 650R 06-08 :LINEAR PUSH Type
    Z750 04-05 :LINEAR PUSH Type
    Z1000 03-06 :LINEAR PUSH Type
    ZX-10r 04-05 USH Type One 1 Shift Rod B
    ZX-10r 06-07 USH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-10r 2008-10 USH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-12r 00-01 USH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-12r 02-03 USH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-12r 04-05 USH Type One 1 Shift Rod A (remove/cut off 5 sections)
    ZX-14r 06-07 :LINEAR PUSH Type
    ZX-14r 2008 :LINEAR PUSH Type
    ZX-14r 09-10 :LINEAR PUSH Type
    Suzuki•GSX-R 600 01-03 USH Type One (1) Shift Rod B (removed/cut off 10mm + rotate spline)
    GSX-R 600 04-05 USH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 600 06-07 USH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 600 2008 USH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 600 09-10 USH Type One 1 Shift Rod A + One (1) Shift Rod C
    SV650 SV650S 03-06 USH Type One 1 Shift Rod B
    SV650 SV650S 07-08 USH Type One 1 Shift Rod A (removed/cut off 10mm)
    GSX-R 750 00-01 USH Type One 1 Shift Rod B (removed/cut off 10mm + rotate spline)
    GSX-R 750 02-03 USH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 750 04-05 USH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 750 06-07 USH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 750 2008 USH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 750 09-10 USH Type One 1 Shift Rod A + One (1) Shift Rod C
    SV1000 03-04 USH Type One 1 Shift Rod B ( + rotate spline)
    SV1000 05-07 USH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 1000 01-02 USH Type One 1 Shift Rod B (removed/cut off 10mm + rotate spline)
    GSX-R 1000 03-04 USH Type One 1 Shift Rod B (removed/cut off 10mm + rotate spline)
    GSX-R 1000 05-06 USH Type One 1 Shift Rod B
    GSX-R 1000 07-08 USH Type One 1 Shift Rod B (removed/cut off 10mm from EACH END)
    GSX-R 1000 09-10 USH Type One 1 Shift Rod A + One (1) Shift Rod C
    GSX-R 1300 Hayabusa 99-00 :LINEAR PUSH Type
    GSX-R 1300 Hayabusa 2001:LINEAR PUSH Type
    GSX-R 1300 Hayabusa 02-07 :LINEAR PUSH Type
    GSX-R 1300 Hayabusa 2008 PUSH Type One 1 Shift Rod B (removed/cut off 17mm from EACH END)
    GSX-R 1300 Hayabusa 09-10 PUSH Type One 1 Shift Rod B (removed/cut off 17mm from EACH END)
    BKing 08-09 USH Type One (1) Shift Rod B
    Yamaha•Road Star Warrior 02-08 USH Type
    •FZ6 04-08 LINEAR PUSH Type
    •FZ1 06-08 PULL Type One (1) Shift Rod B + One (1) Shift Rod C
    •R6 03-05 PULL Type One (1) Shift Rod A + One (1) Shift Rod D (remove/cut off 1 section from the D rod only)
    •R6S 06-08 PULL Type One (1) Shift Rod A + One (1) Shift Rod D (remove/cut off 1 section from the D rod only)
    •R6 06-07 PULL Type One (1) Shift Rod A + One (1) Shift Rod D (remove/cut off 4 sections from
    •R6 08-12 PULL Type One (1) Shift Rod A + One (1) Shift Rod D (remove/cut off 4 sections from the A and remove 2 sections and -16mm from the D rod)
    •R1 02-03 PULL Type
    •R1 04-05 PULL Type One (1) Shift Rod A + Two (2) Shift Rod C (remove/cut off 2 sections from only 1 of the shit rod C's)
    •R1 07-08 PULL Type One (1) Shift Rod A + Two (2) Shift Rod C (remove/cut off 2 sections from only 1 of the shit rod C's)
    •R1 09-12 PULL Type One (1) Shift Rod A + Two (2) Shift Rod C
    Re: Using a quick shifter - Helpful
    SWANSEA MA
    Sorry for all the smiles didn't know it would do that. This forum stuff new to me. How would I post without doing that crap?
    That's just what happens when ": P" appears in the post (minus the space between them). Add a space & it'll go away.
    SWANSEA MA
    Thanks for the info. Another ? How do u set up the box on the bottom of your post's with ur sponsors & bike info ect?
    At the very top right of any page on NESR you'll see the "Settings" link. Click that, then "Edit Signature".
    This link may take you right to it... not sure. http://www.nestreetriders.com/forum/...=editsignature
    Aprilia
    Ducati
    848 2008 PUSH Type One 1 Shift Rod A (remove/cut off 6 sections)
    1098 07-08 PUSH Type One 1 Shift Rod A (remove/cut off 6 sections)
    1098R 2008 PUSH Type One 1 Shift Rod A (remove/cut off 6 sections)
    1198 2009 PUSH Type
    Honda
    CBR 600rr 03-04 PUSH Type One 1 Shift Rod A
    CBR 600rr 05-06 PUSH Type One 1 Shift Rod A
    CBR 600rr 07-08 PUSH Type One 1 Shift Rod A
    CBR 600rr 09-10 PUSH Type One 1 Shift Rod A
    CBR 929rr 00-01 PUSH Type One 1 Shift Rod A
    CBR 954rr 02-03 PUSH Type One 1 Shift Rod A
    CBR 1000rr 04-05 PUSH Type One 1 Shift Rod A (remove/cut off 1 section)
    CBR 1000rr 06-07 PUSH Type One 1 Shift Rod A (remove/cut off 1 section)
    CBR 1000rr 2008 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C
    CBR 1000rr 09-10 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C
    Kawasaki
    ZX-6r 03-04 PUSH Type One (1) Shift Rod A
    ZX-6r 05-06 PUSH Type One 1 Shift Rod A (remove/cut off 6 sections)
    ZX-6RR 2003 PUSH Type One 1 Shift Rod A
    ZX-6RR 2004 PUSH Type One 1 Shift Rod A
    ZX-6RR 05-06 PUSH Type One 1 Shift Rod A (remove/cut off 6 sections)
    ZX-6r 07-08 PUSH Type One 1 Shift Rod A (remove/cut off 6 sections)
    ZX-6r 09-10 PUSH Type One 1 Shift Rod A
    ZX-10r 04-05 PUSH Type One 1 Shift Rod B
    ZX-10r 06-07 PUSH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-10r 2008-10 PUSH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-12r 00-01 PUSH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-12r 02-03 PUSH Type One 1 Shift Rod A (remove/cut off 2 sections)
    ZX-12r 04-05 PUSH Type One 1 Shift Rod A (remove/cut off 5 sections)
    Suzuki
    GSX-R 600 04-05 PUSH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 600 06-07 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 600 2008 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 600 09-10 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C
    SV650 SV650S 03-06 PUSH Type One 1 Shift Rod B
    SV650 SV650S 07-08 PUSH Type One 1 Shift Rod A (removed/cut off 10mm)
    GSX-R 750 00-01 PUSH Type One 1 Shift Rod B (removed/cut off 10mm + rotate spline)
    GSX-R 750 02-03 PUSH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 750 04-05 PUSH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 750 06-07 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 750 2008 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C (remove/cut off 3 section from each rod)
    GSX-R 750 09-10 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C
    SV1000 03-04 PUSH Type One 1 Shift Rod B ( + rotate spline)
    SV1000 05-07 PUSH Type One 1 Shift Rod B ( + rotate spline)
    GSX-R 1000 01-02 PUSH Type One 1 Shift Rod B (removed/cut off 10mm + rotate spline)
    GSX-R 1000 03-04 PUSH Type One 1 Shift Rod B (removed/cut off 10mm + rotate spline)
    GSX-R 1000 05-06 PUSH Type One 1 Shift Rod B
    GSX-R 1000 07-08 PUSH Type One 1 Shift Rod B (removed/cut off 10mm from EACH END)
    GSX-R 1000 09-10 PUSH Type One 1 Shift Rod A + One (1) Shift Rod C
    •R1 02-03 PULL Type
    OR You can go here also.................
    http://www.powercommander.com/powerc...trod_kits.aspx
    FIXED
    I never found quickshifters to be reliable enough for the racing environment. As soon as you start bending shit up, and racing in the rain, these things are frustrating as hell.
    Are these factory quick shifters any more reliable?
    I've never had a problem with mine.
    Is it aftermarket? brand?
    SWANSEA MA
    Thanks. I've installed all of 20 Dyno jet quick shifters & had an issue with only one which happened to be on my own bike, but after talking to Dyno jet it was an issue just on my model bike. They sent me a fix for it & it's been fine since
    All I hear is the cut off time is the big thing to get right.....but I never had or used one
    Dynojet. John at Dyno Solutions installed it when he did my PCV and SFM and it has been great.
    SWANSEA MA
    The standard kill time is 6 mill seconds. Witch works great for 90% of bikes. If bike shifts ruff add 1 or 2 mill sec. You can also set kill time per gear as well. I have on all 5 of my bikes & installed on a bunch of customers bikes they work great as long as they are set-up correctly which I think is very easy. most issues are due to human error
    Adrenaline Cycle
    Swansea,MA
    Dyno Jet Tuning Center
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    ADRENALINECYCLEINC.COM
    Like us on Facebook
    [IMG]http://www.facebook.com/AdrenalineCycle1?ref=hl
    my DynoJet has always worked fine on my GSXR
    Only time I had issues on my SV was when the plug came loose. Cured with a zip tie.
  1. For Sale - Parts & Tools | dynojet pull style quick shifter and module
    By sdog30 in forum For Sale
    Last Post: 05-02-16, 01:46 PM
  2. Replies: 20
    Last Post: 07-15-12, 09:38 PM
  3. NIB Dyno Jet Pull Quick Shifter
    By Pigman in forum For Sale
    Last Post: 03-28-11, 08:25 PM
  4. Quick shifter push type
    By dudutzu in forum For Sale
    Last Post: 08-15-10, 08:45 PM
  5. Quick Shifter
    By wortown03 in forum Bike Maintenance
    Last Post: 02-26-08, 07:01 PM
