Results 1 to 25 of 37
Tank repair?
    Braap Baggey22's Avatar
    Westford, VT
    Tank repair?
    Looking to see if anyone knows of a good shop that can repair a dent in a motorcycle tank. I called a few PDR places around me, but they're all mobile and don't want to give a quote without looking at it first and don't want to schedule a time so they would come look at it "when they can fit it in".
    Tank is removed and fuel pump is removed, access to the dent is really easy with the fuel pump out.
    I'm in Vermont, but travel down to Boston area every few weeks. Thanks!
    Tank repair?-img_5551-jpg
    holland ma.
    Re: Tank repair?
    That looks like it hurt your baby maker.
    Lifer obsolete's Avatar
    Norf Sho
    Re: Tank repair?
    If his baby maker made that dent I don't think anyone is letting him put it anywhere near where babies are made.
    -Alex
    Arlington MA 02474
    Re: Tank repair?
    From what I've seen on vintage bike forums, a "dent" of that size usually requires cutting a big access hole in the bottom, then beating out the dent from inside, all done with expert body work technique, then welding the access panel back in place.
    Westford, VT
    Re: Tank repair?
    The dent is directly over the fuel pump. So access is pretty easy.
    Tank repair?-img_5570-jpg
    Arlington MA 02474
    Re: Tank repair?
    Quote Originally Posted by Baggey22 View Post
    "Proceed as the way opens."
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Tank repair?
    In my experience, that dent will take a significant amount of persuasion to remove. MC tanks are tough and most likely will involve filler and a total repaint.
    Posted by Jane in BoxChat
    Re: Tank repair?
    I don't think that is worth repairing. surely a good used or even new old stock tank would cost less. repainting alone would cost hundreds.
    Re: Tank repair?
    This is not a dent, you collapsed the tank. Everything is fixable, but there’s a lot of labor in something like this. I’d be looking for a replacement tank.
    Re: Tank repair?
    I mean, it is pretty symmetrical. Maybe just put a sticker on it. lol
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Tank repair?
    Ive seen PDR do some crazy shit
    Westford, VT
    Re: Tank repair?
    It’s for a track bike. Another Copart auction bike. So paint will most likely be rattle can.
    Arlington MA 02474
    Re: Tank repair?
    For a track bike, if it doesn't leak, maybe just make up a thick tank pad with velcro attachment.
    Back in ye olden days, seems like 100 years ago, and it will be soon, we always stuck a comfy pad on the tank ...
    Re: Tank repair?
    Even still. I do this all the time. I have a collection of dented R6 tanks. We fixed 1. never again. Tanks are super thick steel with complex curves. Dents, and especially creased ones, cannot be pulled with welding rods. Then you have holes to fill. then paint. so even with rattle can, finding someone to do the job for a reasonable price is not likley. find another tank...
    holland ma.
    Re: Tank repair?
    I like the pad idea. you could probably contour it with a razor and get it to fill the dent in perfectly. Might even make things more comfortable.
    Re: Tank repair?
    That's going to end up being a $1000+ to repair, whether it's PDR or grafting on a replacement section of tank, etc.
    Best you could do for cost effectiveness IMO is to grab a few cutoffs of 2x4 and a dead blow hammer and start bashing
    Central Maine
    Re: Tank repair?
    I'm gonna say $250 for pdr, $7.99 for a can of spray paint
    Re: Tank repair?
    Perfect places won't touch it I'm my experience. It's nothing like fixing sheet metal on a car.
    Sent from my SM-S901U using Tapatalk
    Central Maine
    Re: Tank repair?
    Ok, My experience has only been with cars and I was very impressed.
    Norf Sho
    Re: Tank repair?
    Would PDR even be able to get the crease to go back? Every time I've seen them work its much smaller tools to bend a little. I've never seen them work big folds before.
    -Alex
    Oct 2020
    Chelmsford, MA
    Re: Tank repair?
    make this thing I saw on the Internet
    Dec 2009
    Re: Tank repair?
    Having used similar technique with freeze plugs to push out a crushed mid pipe with pretty good success I'd say give this a shot. In my case I filled the pipe with water, plugged both ends and put it in the freezer. Took 3 rounds to push out the dent. As the tank would be a bit to fit in a freezer I'd give the air a shot. Cheap and easy to try. May want to gently heat the tank as you add a little pressure to help it want to stretch. Seriously, give it a try.
    Arlington MA 02474
    Re: Tank repair?
    Sure, but wear eye protection at least, or maybe bomb disposal gear.
    Westford, VT
    Re: Tank repair?
    Quote Originally Posted by 02redhawk View Post
    I was thinking about trying this. I assume I should try to add air with the fuel pump out, not in. Don't want to damage the fuel pump with air pressure. So I'll have to make two plugs for the fuel fill and the fuel pump hole. Also plug the vents.
    Re: Tank repair?
    I have done some tanks with air. One that was seriously dented like yours. It was going great, pinging and popping as little dents came out, so we were excited and upped the pressure. more pinging and popping until finally, we weren't making any more progress on the big dent. We were wondering why it still sounded like dents were coming out. We turned the tank over and got our answer. The bottom of the tank is thinner metal than the top, and we inflated that sucker like a balloon! Probably held 5 gallons when we were done with it. LOL Needless to say it went in the bin.
    Not to be Debbie downer, but...
