Results 1 to 25 of 29
SRX250 Project
    SRX250 Project
    So a few weeks ago I picked up an 87 Yamaha SRX250 as a winter project from Doug (Sheppo). Thanks man! The srx is not a common bike which is why you might not have heard of it. 87 was the debut of the srx250 in the us as well as the ex250. The ninja made more hp than the srx mostly because the srx was air cooled and the ex was water. Either way the srx was only imported 1 year because of the success of the ninja.
    My plan is to get it completely stripped and do new painting and refresh.
    Here's a before.
    Here's where I'm at after last night. I'm going to go with the same scheme as the R1. The 50th anniversary colors. Frame is going to be black, tank yellow, body yellow, rims and rearsets and tripleclamps black, etc.
    Two many 2 strokes
    Bradenton FL
    Re: SRX250 Project
    I have always loved there bikes.... cool little bike. Is the paint that bad that you need to paint it?
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: SRX250 Project
    *SUBSRCIBED*
    Posted by Jane in BoxChat
    Re: SRX250 Project
    Do eeit.
    I find some irony in the fact that you have a project with a red frame that you are gonna paint black and I have a project with a black frame that I am gonna paint red.
    Re: SRX250 Project
    Quote Originally Posted by DynoTune View Post
    It's not bad but the tank has a dent. And more than anything I just want it yellow.
    Do eeit.
    Haha the red frame isn't bad but I gotta go wiz khalifa on this one.
    Got it down to the frame this am. Digging into the motor and tranny next. Needs gaskets and the clutch is frozen. Going to repaint or pc the engine cases while it's all apart.
    Re: SRX250 Project
    Had to google it.. just FYI.
    Re: SRX250 Project
    Generation gap
    Re: SRX250 Project
    Sometimes the gap is intentional..
    Feb 2012
    Re: SRX250 Project
    So jelly
    Too many bikes to list
    Mosdt likely drunkd
    Re: SRX250 Project
    Cool. A friend scored one last year to go along with his VTR250 (interceptor).
    2013 ZX6R-636
    Member peterz85's Avatar
    May 2011
    East Hampton, CT
    Re: SRX250 Project
    That thing is dying for an rz motor
    Pete
    Re: SRX250 Project
    Quote Originally Posted by peterz85 View Post
    Pete
    I wish I could afford it!
    There was no oil in the engine when stripping the bike so I opted to totally disassemble the motor to check for wear. There was a good amount of water in there so I'm glad I did. Cylinder walls and piston seem decent so ill reuse those. Head also looks good. Looks as if it had oil in it when it ran last. Need a flywhel puller to continue and to borrow my cousins impact to get the clutch basket off. Here she sits.
    Bellingham MA
    Re: SRX250 Project
    nice man, that bike's getting some much deserved lovinz!
    Feb 2012
    Re: SRX250 Project
    Gonna try to pick this up.
    http://boston.craigslist.org/bmw/mcd/4258595391.html
    Can someone explain the carbs? It seems like it's got one flat side and one vacuum type ???
    Mosdt likely drunkd
    Re: SRX250 Project
    One is mechanical and the other is a cv slide. Cv supplies the main power and mechanical starts to work in the higher rpms. I looked for a replacement so I could have 2 mechanical carbs but I haven't found anything that would fit easily. Intake boots are known to go on these too. Check for cracks. They are expensive to replace but you can still get them from Yamaha. And the mechanical carb piggybacks on the cv carbs float bowl. It doesn't have one of its own.
    Feb 2012
    Re: SRX250 Project
    Interesting set up. I'm going to look at that one tomorrow. We'll see.
    Mosdt likely drunkd
    Re: SRX250 Project
    You're a mad tinkerer Smutty. This I have learned about you.
    Senior Member B440's Avatar
    Jul 2012
    Thompson, CT
    Re: SRX250 Project
    Don't you mean; The mechanical is the main power and CV opens up in higher rpm? Like a 4-barrel carb on a car.
    Ack. I hate that setup. The TT350 and XT350 used the same design. I had a hard time finding main jets for the secondary CV carb.
    Re: SRX250 Project
    Quote Originally Posted by B440 View Post
    That's what I thought made sense but that's not what I heard from others on the topic. And yes the carbs are the same on the xt and tt. I want to ditch these so bad. But $$$$$.
    Re: SRX250 Project
    I can get a jet kit for that beast from Japan, $180... dual FCRs will run $850.
    Edit: Ninja 250 carbs are supposed to use the same intake diameter and spacing...
    Re: SRX250 Project
    Paul... this is the mad tinkerer hahaha!
    I might just have to source a set of ninja 250 carbs.
    Jul 2012
    Thompson, CT
    Re: SRX250 Project
    Ok then the SRX setup is backwards from the TT/XT carbs. I am 100% certain on the dirtbikes (mechanical main, CV secondary) because I had to work on one for several weeks.
    If you're right about the SRX, then it would be easy to get two mechanical carbs, one from the SRX and the other from a TT or XT350.
    Edit; You're wrong. They're the same. Just did an image search of the carbs on an SRX. Damn, I got all excited too....
    Re: SRX250 Project
    Haha good to know man. Although now that I know these are the same as the ex250 there's no way in hell these are going back on!
    Feb 2012
    Re: SRX250 Project
    Can't get that guy in Hudson on the phone. Grrr
    Mosdt likely drunkd
    Re: SRX250 Project
    you need a banshee motor.
  1. YSR project...
    By Expat in forum General Bike Related
    Last Post: 08-31-11, 09:08 PM
  2. need an R6 project ??
    By Jim in forum For Sale
    Last Post: 05-13-09, 11:48 AM
  3. my project
    By 97BlownSaleen in forum General Bike Related
    Last Post: 03-12-09, 08:29 PM
  4. SRX250 Rebuild: Cafe racer or Streetfighter?
    By RavenHawk in forum General Bike Related
    Last Post: 07-20-08, 06:59 PM
  5. New Project
    By RGVER in forum General Bike Related
    Last Post: 02-25-07, 06:39 PM
