Anybody know of a Dyno Shop that has the necasary cable and software to tune a HRC ECU? I just picked up a JSB ECU and want to tune the fuel ratio directly into the ECU so I can jettison the PC3.
I have the cable and software for the HRC ECU.
PM me and we can discuss a sale or loan.
derek
Any dyno shop should know how to use it. I have the instruction book, but it's very similar to the power commander software-wise, except you can do shit like move the rev limiter wherever you want it.
The dyno place will do a dyno run and make adjustments in the HRC program and download them to the ECU just like you would a power commander.
derek
The bike is an 05, but the motor, harness, and JSB ECU is all 06. I bought the motor used, sent it out to KWS for 2mm overbore, cam, head work and rods.
Its a OEM harness, I understand there is some debate about if you can use a OEM Harness to tune the HRC ECU, but I think you can.
Well, you are welcome to borrow the stuff :-)
Thanks, I'll give you a shout as soon as I can Tee up a dyno center.
