Results 1 to 21 of 21
Dyno results
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Exclamation Dyno results
    Post'em up....
    122.8 rwhp
    68.x(I forget) ft. lbs torque
    but..lol according to TLRman.... 122.8 x 1.018=125rwhp
    The last time I went was back in March I think at New England Motorsports and it was cold and rainy it hot 121.5. I did an airboxectomy and added a K&N. I guess it works ok...lol but Bad Dog's orange Z hit 123 even.. with a set of yosh slip-on's which I am told doesn't add any hp..
    Oct 2001
    Bedford, MA
    Dyno results
    97.1hp/54.0lb-ft
    Assuming the 1.018 correction, 98.8...
    Which at least tells me my motor is at least making what it's supposed to.
    All in all I think I care more about the tires & suspension feeling right on any given day than a few horsepower!
    Ben
    Member Zero's Avatar
    Nov 2002
    Attleboro, MA
    Dyno results
    1997 TLS
    120.7 HP / 74 ft/lbs.
    Now I have to get the TLR motor built before October.
    Posting Freak
    Aug 2003
    Coudersport, PA
    Dyno results
    Can someone expalin the dyno results in "dummy" terms. I just don't understand it, and I want to. I want to be able to read the numbers and go "eh, that makes sense! That dude has a sweet bike, blah, blah, blah"
    Thanks ahead of time for anyone willing to explain.
    Getting back into the game! Looking for my next bike!
    I Dance With Will
    Oct 2002
    unknown
    Dyno results
    zx10r
    max hp=148.8
    max torque=74.0
    "fuckit!"
    Lifer SEVENSGT's Avatar
    Warwick, RI
    Dyno results
    104.3hp rear wheel, 67.2lbs
    runnin a little lean from 3g to 5g's with the correction 106.17
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    Dyno
    Beth:
    Dyno numbers are a way to run your bike or car on a machine with big rollers or that attaches two/four (for AWD or 4WD) pots to your "car".
    During a "pull", the rollers now provide resistance (to rolling) against your tires so the engine work to "roll" the (now harder to turn rollers) can be measured in torque and HP.
    Computers and graphs are used to show the work output over time and to give you the graph which everyone shows their buddies.
    The machine is used in a specific way (gear, start RPM etc, to determine how much actual HP the vehicle is putting out.
    It is expensive and usually is used to verify claims that this exhaust or this K&N filter actually added x amount of HP for the $$$$ someone spent.
    For instance:
    You buy a bike with "100 HP" ( a lot for a bike), and drive it around and dyno it, you'd expect it to be around 100 HP.....
    Ford Cobra owners dyno'ed some special edition car that supposedly put out near 300 HP, and found out it only did the same as the older model (I think it was an actual DROP in HP vs. the other) and some buyers did a class action suit over it.
    Turns out that if no-one contested the Ford numbers, the owners would have been smoked.
    Engine tuners use the dyno to "real world" test their product too.... and to get the claimed HP numbers. However, the graph is useful to determine whether a "mod" is really worth the peak HP they print out.
    If your bike makes 100HP or near that in a bigger area on the graph, it may be better than a "mod" where the HP spikes up to some number higher than 100 (in this example) for a second.
    There are many schools of thought along the HP and torque curve....................... flatter torque curves mean more driveability.
    Say you rolled on a boosted turbo bike that hit this huge spike in power during its RPM climb, the wheels may uncontrolably spin or break loose and make the bike "twitchy" to say the least...........
    HTH - Suf Daddy
    Suf Daddy.
    Nov 2003
    Numbers
    Supposely, mine from the factory, puts out 136HP (carb)
    the fuel injected 'Birds put out near 172?
    Sourced:
    I'll check.http://www.cbr1100xx.org/newhome.html (no graph)
    use the left scroll bar to go to, XX specs, then below it to Performance testing data.
    Some of the Torque graphs measure in Newton Meters (Nm) not our ft/lbs Foot Pounds............
    -Suf Daddy
    Suf Daddy.
    granite state
    Re: Numbers
    Or
    fuel injection adds 36 hp?
    iginally posted by Suf Daddy
    Sourced:
    -Suf Daddy
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    Re: Dyno results
    i told ya the orange was way faster than the fast black one!!!
    Originally posted by bigred875
    Post'em up....
    122.8 rwhp
    Brent LRRS #772
    2006 KTM 560 SMR
    Dyno results
    I don't care about peak HP, who had the most at 5000 rpm
    I Dance With Will
    Oct 2002
    unknown
    Dyno results
    why at 5000rpm? could someone explain?
    if the peak torque is at 10k rpm, guess what rpm im gonna be if i want to make a quick pass.
    edit: well on the straight that is.
    "fuckit!"
    Senior Member slingblade's Avatar
    central, ma
    Dyno results
    About 65ftlbs Only 5ish away from peak!
    http://gbelli.cz28.com/rc51-dyno.html
    Dyno results
    no, I said HP @ 5k
    I just picked what I thought might be an average cruising rpm,
    when your cruising down the road at 5k, you don't have 150hp on tap till you get your revs up.
    I'm trying to get an idea what bike has the most power immediatley available on the street
    I Dance With Will
    Oct 2002
    unknown
    Dyno results
    since you'r not talking racing, all it takes is a quick down shift really. only a second.
    "fuckit!"
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Dyno results
    122.3 hp @ 61 ft lbs. Don't ask what the air fuel looked like. I wish my jetting were DONE!
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    I'm Sorry, What? Jank's Avatar
    Apr 2002
    North Walpole, NH
    Dyno results
    112.4 hp.
    73.1 torgue.
    Chris J.
    Nov 2003
    Re: Numbers
    Yeah, I say THAT much of an increase is suspect, but.... I could be wrong. Carb vs. Fuel Injected. 136 vs 172.
    Beth, here's a chart
    http://www.nestreetriders.com/forum/...threadid=11515 scroll down.
    -Suf Daddy
    Originally posted by blackvfr
    Suf Daddy.
    Member Bad Dog's Avatar
    Jul 2004
    Candia, NH
    Dyno results
    123.0 horsepower
    67.7 torque
    and for RandyO....at 5000 rpms about 52 horsepower and 55 lbs of torque
    Apr 2004
    chicopee
    Dyno results
    Good numbers guys, wish I could have gone out there with ya.
    I would say that CBR100XX number of 172hp is at the crank, not the wheel.
    That 5000RPM question, on my Busa I have 86HP and 87ft/lbs at the wheel at 5grand.
    (not that it matters since I didn't go to this with you guys)
  1. #99 Classic Results 14's
    By Kitt in forum Race Reports
    Last Post: 06-21-10, 11:45 AM
  2. Finding Old OLD Results
    By strgt in forum Pit Area
    Last Post: 01-27-10, 07:25 PM
  3. Old Daytona CCS ROC lap results
    By nt650hawk in forum Pit Area
    Last Post: 08-29-08, 11:08 AM
  4. Jay's Results...
    By Stoneman in forum Pit Area
    Last Post: 05-19-03, 11:18 PM
