Results 1 to 13 of 13
ex500 gravity petcock
    san fran
    anyone know where i can buy a non vacuum operated petcock for an 88 ex500? looked around on ex-500 and didnt find anything
    Tuono
    Re: ex500 gravity petcock
    step 1 - remove petcock
    step 2 - open petcock
    step 3 - remove all the shit inside (rubber diaphragm and spring)
    step 4 - make your own 0-ring gasket
    step 5 - reassemble petcock with only the 0-ring gasket inside
    step 6 - ?
    Step 7 - profit
    Or you can get a Pingle.
    san fran
    you got a part number? the one in my tank has two bolts that hold it in, but i cant find anything like that on pingels site
    Tuono
    All of Pingle's units are thread in style... but they sell mounting plates for two bolt setups like the EX uses, so you get to choose which style petcock you want, and then just use the right mounting plate to install it on your tank.
    If you go with a non race unit with a reserve, plan on pulling the screen off and trimming down the primary feed tube, they make them stupidly tall for some reason. Use your old petcock as a guide.
    san fran
    ahh i see now. just for clarification, for example they sell a 34mm mounting plate. This 34mm dimension is center to center for the mounting holes? im assuming you've used them before? good quality? leaks? its for my track bike so no need for a reserve.
    Tuono
    Email Pingle support with your mounting dimensions, and how you want the fuel line to enter the petcock (ie straight down, out to the side, etc) and they'll get you all the info you need.
    I put one on my GS for I'm guessing the same reason you're looking to ditch the OEM setup, the vacuum setup doesn't hold up over time, and likes to starve the bike for fuel in some situations. Mine works great, although I spent a lot of time blaming it for what turned out to be electrical and other carb issues I believe. Since sorting those, the bike's run like a top with it.
    What Pete said. Just empty that thing out. Worked for me.
    san fran
    ill try gutting it first, i just didnt know if the "off" feature would still work
    Tuono
    Yup. Off still works.
    Only difference is that On is On all the time, not just when there is suction.
    san fran
    perfect, so all i have to do is cap off the where the vacuum line plugs into the carb right?
    Tuono
    Yup!
    san fran
    sweeeeeet
    Tuono
  1. Wanted - Parts & Tools | SV650 Petcock/Filter
    By CEO in forum Wanted
    Last Post: 06-07-17, 03:57 PM
  2. switching from vacuum to manual petcock
    By breakdirt916 in forum Bike Maintenance
    Last Post: 08-20-13, 08:25 PM
  3. Product | Zero Gravity
    By VinceF2 in forum Business & Product Reviews
    Last Post: 03-23-11, 07:05 PM
  4. gravity cavity vid
    Last Post: 06-03-10, 09:28 AM
  5. Petcock on or off?
    Last Post: 12-13-07, 08:58 PM
