Results 1 to 15 of 15
Dead Battery?
    Junior Member Mike02048's Avatar
    Oct 2009
    Mansfield, MA
    Dead Battery?
    I have a 2009 Kawi ZX6R. Today was pretty nice so I decided to take the cover off the bike for my first spring ride. I turned the key which started the fuel pump and lit up the gauges, but when I hit the start switch the engine didn't turn over. Instead all I heard was a clicking sound.
    Can I assume that even though I had the battery on a tender all winter that it still did not have enough power to start the engine? Or do I have a more serious problem? BTW-The bike was running fine when I put it away for the winter. And my garage is not heated.
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: Dead Battery?
    ya sounds like the battery to me. I have the same bike and it did the same thing to me a few days ago. I just charged it for 30 minutes and she fired right up. you could also push start it and go for a ride.
    www.bostonmoto.com
    Ride to live, live to ride
    Oct 2009
    Mansfield, MA
    Re: Dead Battery?
    Quote Originally Posted by Danz19899 View Post
    This may be a stupid question, but doesn't the tender keep it charged up? Do I have to charge it another way?
    Lifer eboos's Avatar
    Re: Dead Battery?
    I must be doing something wrong, but I've never been able to push start anything larger then my 125.
    Re: Dead Battery?
    Quote Originally Posted by Mike02048 View Post
    It does both. Do you need to borrow one?
    Oct 2009
    Mansfield, MA
    Re: Dead Battery?
    Quote Originally Posted by eboos View Post
    Thanks, but I've had it on a trickle charger all winter. But I left the battery in the bike and the garage is not heated, so I'm thinking that the cold might have affected the bike.
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Re: Dead Battery?
    I`m betting the on the battery as long as the tender was ok and hooked up right.
    Re: Dead Battery?
    Batteries don't live forever; they have a certain life span. The combination of age and cold may have put yours over the edge.
    Go fast. Have fun. Repeat.
    Grafton, Ma
    Re: Dead Battery?
    really? i've pop started 600's way to many times. even had 2 pop start degsy's gsxr 750 a few times when he let me borrow it and the battery was toast. not hard just takes practice lol
    www.bostonmoto.com
    Re: Dead Battery?
    Quote Originally Posted by dontpanic View Post
    True, but an AGM battery should last easily between 3-7 years, with 3 being the extreme short side. Regular wet batteries, I would expect, wouldn't go dead in 2 years.
    Derry NH
    Re: Dead Battery?
    And even a slight hill makes it so much easier. I've had to push start my R6 countless times.
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Dead Battery?
    Batteries can be purely luck of the draw.
    Factory battery in my '04 12R crapped out in it's 6th year. Never used a tender. The Walmart special replacement survived this past winter without a tender.
    The previous Yuasa replacement battery in my SV650 lasted 3/4 of a season before it died. It was also replaced with a Walmart special (for just over half the price) and it has survived 2 winters without a tender.
    I averaged about 3-4 years with my KZ1000 and KZ1100.
    The factory battery in my Mazda developed a shorted cell 2 months after I bought the car brand new. It was replaced under warranty and has been going strong for a few years now.
    And when you pop start a 500+ pound KZ1100 down a steep hill, make sure you turn the fuel on. I pushed it all the way home before I realized I was a dumb-ass.
    Oct 2009
    Mansfield, MA
    Re: Dead Battery?
    Update: I checked the connections and evrything was tight. So today I attached a regular 12 volt battery charger to the battery (as opposed to the little trickle charger I had it on all winter) and charged it up for a few hours. Then I tried to start the bike and it turned right over. I let it idle for about 10 minutes, shut it off, and plugged it back into the trickle charger. I'll try it again tomorrow. Assuming it starts tomorrow, am I out of the woods? Or should I start to price a replacement battery anyway?
    Grafton, Ma
    Re: Dead Battery?
    i'd see how she does, honestly sounds like you have a crappy trickle charge
    www.bostonmoto.com
    Lifer DuncanMoto's Avatar
    Re: Dead Battery?
    What do you mean by a "regular" charger?
    Your trickle charger... Is it a name brand with an electronic regulator, like Battery Tender, or some no name chinese brand?
    The regular charger you used.... Is it rated for more than 5.0 amps? a car charger? If so that battery is done.
  1. Dead Battery or ???
    By Marc R in forum General Bike Related
    Last Post: 06-16-15, 05:06 AM
  2. Dead battery troubleshooting.
    By backinthesaddle in forum Bike Maintenance
    Last Post: 09-03-12, 10:16 AM
  3. Looks like dead battery...but its not...
    By Romeo in forum Bike Maintenance
    Last Post: 05-29-11, 03:44 PM
  4. Dead battery
    Last Post: 03-07-11, 08:21 PM
  5. dead friggin' battery
    By Awesome in forum Bike Maintenance
    Last Post: 10-31-04, 09:26 PM
