Results 1 to 8 of 8
vp racing fuel
    Senior Member double agent's Avatar
    Sep 2002
    acushnet - yates replica
    vp racing fuel
    I now it comes in differ oct rates, so how high can you go before you start doing some real damage. there is a place I can get some and I dont want to get to strong a fuel. I will probably be running a 50/50 mix. any input would be helpful and appreciated.
    Dec 2003
    Massachusetts
    vp racing fuel
    You want input? Save your money, and run the lowest octane you can. High octane is to revent pre-detonation, which can occur on a highly tuned bike. Unless you running a turbo or something, that means pump-gas, probably regular, unless you've advanced your timing.
    Higher octane, is harder to ignite, therefore resists pre-detonation. It also can leave more carbon deposits in the engine due to incomplete combustion. Its a great myth though.
    StumpyNB
    '11 Kawasaki Ninja 1000
    Northshore/Beverly, MA
    vp racing fuel
    Most of the bikes these days run piss for octane and run well.
    Take the SV1000, it will run delightfully on 87 octane.
    Common rule...start low, if you hear detonation, bump it up a point or 2. (or read your plugs...they tell you everything)
    If you change compression ratios, add more lead on the timing, you may need to go up. BUT..if you can get the squishband tighter, sometime you can get away with running a higher comp ratio, and stay with a lower octane fuel.
    So just to add another nail to the misconception that higher octane makes more power is a false one...
    Oh and another thing..you don't want to mixing any kind of witches brew that comes from VP, or any other race fuel provider....
    vp racing fuel
    A bit of advice passed on to me from people really in the know...
    Run what your engine was designed/built to run on. If your bike was built to run on 87 octane, higher octane petrol most likely won't do you a bit of good. In fact, it could be more harmful than anything...
    MCN did an awesome, in-depth article backed up by extensive dyno testing and researched further with engine tear downs a coupla years ago. It only backed up what knowledgable people have told me...
    vp racing fuel
    Geeeez....
    I didn't know that....
    vp racing fuel
    Originally posted by TLRMan
    Geeeez....
    aka Johnny Valve Stem need4speed's Avatar
    Aug 2002
    Brookfield,CT
    vp racing fuel
    See what happens when you lead Mark to believe he's knowledgable
    John
    LRRS\CCS #714
    2004 Duc 620 monster racebike
    89 EX500 racebike - sold
    98 Superhawk 996
    "To repeat what others have said, requires education; to challenge it, requires brains".
    Diamond Geezer Kip's Avatar
    Nov 2002
    Cranston ,RI
    vp racing fuel
    I thought higher octane is better also until I put it in my bike only to find out the bike like it lost about 5 HP. Just run pump gas or if you want a good low octane race gas try Ultimate 4. But if you only riding on the street you will spend $1,000 a week because it costs $50 for 5gal.
  1. VP Fuel
    By Big Draggo in forum General Bike Related
    Last Post: 07-10-09, 08:38 PM
  2. FS: (2) VP Racing 5 Gallon Fuel Jugs
    By Fitz in forum For Sale
    Last Post: 08-18-08, 06:27 AM
  3. VP Fuel
    By derrickhackman in forum Pit Area
    Last Post: 05-06-08, 02:35 PM
  4. Fuel Used
    Last Post: 04-21-08, 10:24 PM
