Results 1 to 19 of 19
Winter Project Almost Done, Need Some Advice
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    So I bought this 350-4 last year and decided to build a café bike over the winter. It is getting close to being wrapped up. It’s all wired and ready to run but I have a couple details left to sort out.
    Here's The Bike
    http://picasaweb.google.com/ajkouraf...S9ktbX8v74ogE#
    1. Battery - as you can see I left myself no place to mount a battery. I removed the electric start and will kick start the bike, so I don’t need a lot of juice. I want to mount a small battery in the tail section. Could I mount something like this or will it not work on a motorcycle? Battery Link All it has to do is give me enough to start it right?
    2. Rear brake - I moved the foot pegs back and inverted the shifter to give me gp shift and a much better riding position. The down side is I can’t come up with a good way to get the rear brake to work. I have an ad up to try to get some real rear sets but if that does not work?
    3. Exhaust - The stock cans are junk, without them the piped terminate at the foot pegs, which could get a bit warm. Anyone know a place that could bend me some extensions I could clamp on and get then to the back?
    4. Blinkers - 35 year old bike, NH inspection, do I need them?
    5. Any other suggestions would be great. This is my first old bike and first café.
    Lifer catamount's Avatar
    Sep 2006
    Colchester, VT
    Re: Winter Project Almost Done, Need Some Advice
    Sorry to threadjack, but could you tell me (a) what you painted the frame with and (b) how you polished the parts? The polished parts look good! Did you coat them with anything to protect?
    Feb 2009
    Exeter NH
    Quote Originally Posted by catamount View Post
    I painted the frame with standard automotive paint and clear out of a can. Its all in the prep you can get spray paint to look decent. The polishing I do with a lot of sanding, I 320 the paint off, then 400 grit wet the scratches out then 600 then 800 then 1000 then 2000 then use a buffing compound and buffing wheel on a air drill and then some mothers aluminum polish. Its a lot of work but worth it (best to do while drinking).
    Thanks for noticing
    (no i did not coat the polished parts but i did clear coat the brushed parts)
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    lookin' good.
    can't wait until i have a place with a garage so i can have a project to tinker on -- really want a small-displacement CB-4 to cafe out.
    hurray, strikethrough!
    Feb 2009
    Exeter NH
    Quote Originally Posted by spicy View Post
    lookin' good.
    Garage would be nice here to I did it in my basement, gettin her in and out is not fun. the dirt bikes are easier.
    Sep 2006
    Colchester, VT
    Question Re: Winter Project Almost Done, Need Some Advice
    Quote Originally Posted by 6 Fingered Man View Post
    Thanks for noticing
    Thanks for the info!
    The reason I ask is that I plan on doing these exact same things to the '78 CB125 I recently purchased.
    Noob question: what parts did you "brush" and what did that involve? For instance, this is how she currently looks -- do you have any suggestions for cleaning up the engine & case?
    Shock you -jro-'s Avatar
    outside of Boston
    wow, bike is looking sick!!! you should post this in caferacer.net project build forum, those guys would go bananas over it and def hit up caferacer for some advice too, my dad is on there and we just did some battling with my cb to get the footpegs right and tinkering with the rear brake so he'd probably have a few pointers. Keep up the good work
    USCRA #555 - Formula CB
    http://jro555.tumblr.com/
    Feb 2009
    Exeter NH
    I would not do any work to that thing, Just sell it (to me or DanK cheap).
    I would do the motor, all the groves in the head and cylinder and all other small parts with a die grinder and some small sanding disks. Its a bitch to get in there with any thing bigger. Make sure you cover all the intake and exhaust ports really good first, the aluminum goes every where. Brushing it was evenly sanding lines in the aluminum and getting that "brushed" aluminum look. If you do that you have to clear over it because it will quickly oxidize.
    And remember wet sand primer and base coats, It will help. And use heat appropriate paint, engine paint on the motor exhaust paint on the exhaust caliper paint on the brakes and so on.
    Lifer markbvt's Avatar
    Georgia, VT
    Bike looks good.
    If I were you I would run a battery in the tail section. I don't know if that one you posted will work or not. You could also look into the lithium-ion batteries used in some dirt bike dual-sport kits. Or if you're really feeling ambitious, you could try converting the bike to run without a battery.
    As for the exhaust, don't run it with open pipes because IMO it's obnoxious and doesn't look right. I would run something like this muffler from JC Whitney:
    http://www.jcwhitney.com/autoparts/I...D:100000142712
    --mark
    Feb 2009
    Exeter NH
    Quote Originally Posted by -jro- View Post
    Thanks, will do. Ill try and get it up there tonight. Did you get it done with the stock pegs?
    Bike looks good.
    --mark
    Open pipes are obnoxious but cheap, hadn't given Lithium any thought don't they tend to explode? I would love to convert it to run with out a battery but unless I am mistaken that's a lot of $$$$ What would I need to do it? nice find on the pipe. Have to do a 4 into 2 type setup.
    Member clutch's Avatar
    Oct 2008
    Good job 6FM,
    I love seeing new fire breathing from old steeds.
    Thanks for sharing.
    Raymond NH
    That's really cool!
    Planning to put ther airbox back in? It'll run better with it.
    Epping Auto Salvage has an exhaust pipe bender. I bet they could rig something up to a muffler for ya. Failing that, try Skip's Custom Exhaust in Plaistow.
    Rear brake needs some one-off billet solution. I'd figure that out last.
    That battery should be OK, igniton systems don't have much drain. If there's a ballast in the ignition system, you may want to remove it and go for a lower voltage solution.
    I like blinkers, but I suspect you can legally leave them off. LEDs would be cool.
    Lifer Evil_Weasel's Avatar
    Over the Highside
    i had a race NSR running without electric start. it had a 12V commercial fire alarm battery. basiclly just enough juice to complete the circut and make starting a bit easier. not sure if that would work on a bike with lights and road gear but they are small, cheap and light wieght.
    As usual, your post displays a complete lacking in any fucking idea what you're talking about.
    Hey, at least you're consistent.
    Feb 2009
    Exeter NH
    That's really cool!
    That battery should be OK, igniton systems don't have much drain. If there's a ballast in the ignition system, you may want to remove it and go for a , lower voltage solution.
    No air box, I have some cone filters on the way. Ill try Epping It does not have to be fancy I will just wrap it in header wrap. Thanks for the battery input for 9 bucks cant go to wrong unless it burns some other part up.
    I fitted 2 amber led's in the tail it looked looked a gay robot. I pulled them out before ever wiring them onto the bike.
    As for the rear break if i have to ill just get rid of it. I'd love to find a way to hook it up but if I cant, I cant good riding position comes first.
    Ballast in the ignition?? explain please.
    Last edited by 6 Fingered Man; 03-05-09 at 07:38 PM. Reason: read it more carfully
    Feb 2009
    Exeter NH
    Quote Originally Posted by Evil_Weasel View Post
    Awesome, just what i wanted to hear some one who actually did it. Thanks you rock.
    Over the Highside
    glad i could help...that's a bad ass project by the way. she is looking good. i bought a CB550 that i was planning on cafe' racering...but some how i traded it and now find myself owning yet another track bike.
    Feb 2009
    Exeter NH
    HUH... too bad. If you run into another keep it.. or let me know ill find something to trade ya
    Raymond NH
    some ignitions are designed to run on reduced voltage so that when the starter is cranking, and drawing the battery power down, the ignition still gets "normal" voltage. Once the starter is disengaged, the battery voltage goes back to 12+V and the ignition system would be over-powered. To prevent this, there's a ballast resistor that's in-line with the igntion system when the starter is not running.
    Feb 2009
    Exeter NH
    Cool thanks, learn something new every day, I'll look into it.
  1. my winter project
    By Wishbone in forum General Bike Related
    Last Post: 06-17-07, 11:08 AM
  2. winter project almost done
    By Evil_Weasel in forum General Bike Related
    Last Post: 03-26-07, 06:38 AM
  3. Winter Project
    By MsHap in forum General Bike Related
    Last Post: 01-30-05, 09:04 AM
  4. My winter project....what do ya think???
    By ducatiwheelie in forum General Bike Related
    Last Post: 04-14-04, 06:51 AM
