Results 1 to 12 of 12
fastlane
    Lifer smf's Avatar
    Nov 2006
    fastlane
    anyone ever mount your fastlane transponder to the underside of your windscreen with their supplied 'supervelcro sticky pads'? if so does it hold?
    Scott
    Member FastJohnny's Avatar
    Jul 2006
    Springfield, MA
    fastlane
    I was thinking about mounting one under the rear cowl. Assuming they use a radio signal it should work right?
    2004 GSXR 600
    fastlane
    I've mounted mine to the really severe curve of the upper part of my double bubble windscreen and it holds just fine.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    fastlane
    works in a jacket arm pocket too.
    that way no worry about it getting forgotten and ripped off.
    Lifer Wishbone's Avatar
    Jul 2006
    fastlane
    ditto
    Raymond NH
    fastlane
    Mine holds on the underside. It did not work inside my tankbag, even in the map pocket. Seems to need to not be horizontal.
    Lifer smf's Avatar
    Nov 2006
    fastlane
    cool. thanks for the input
    Scott
    Work U HBerry's Avatar
    Nashua
    fastlane
    Mine has worked the few times I have gone through the toll being in my tankbag. It is right under the map pocket and it had no problem reading it.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    fastlane
    i put mine in the trunk. but the fact of the matter is... who cares if it works or doesnt. in the case that they happen to take a picture of your plate for "running" it they will run your plate and see that you have an account and charge you accordingly. its not your fault that they dont offer a motorcycle solution. i run the EZ pass up here all summer and sometimes i even have my transponder. never had a problem
    fastlane
    Quote Originally Posted by akira700 View Post
    That's a good tip.
    Lifer smf's Avatar
    Nov 2006
    fastlane
    ome
    i put mine in the trunk. but the fact of the matter is... who cares if it works or doesnt. in the case that they happen to take a picture of your plate for "running" it they wilawesl run your plate and see that you have an account and charge you accordingly. its not your fault that they dont offer a motorcycle solution. i run the EZ pass up here all summer and sometimes i even have my transponder. never had a problem
    awesome advice all around. thanks everyone
    Scott
    fastlane
    That's basically how I look at it. I just slide it in the clear map pocket of my tankbag. Sometimes it reads it, sometimes it doesn't. It's never been an issue for me when it doesn't pick it up, no charges or no-no letters or anything. I'm not concerned either way...
  1. Using Fastlane w/ tinted windscreens
    Last Post: 11-19-07, 04:37 PM
  2. FastLane
    By FastJohnny in forum General Bike Related
    Last Post: 04-12-07, 04:12 PM
  3. Fastlane?
    By Matt K in forum General Bike Related
    Last Post: 04-27-03, 10:41 AM
