Page 5 of 9 FirstFirst 123456789 LastLast
Results 101 to 125 of 210
Your favorite ignorant comments?
  1. #101
    Tucson, AZ
    Re: Your favorite ignorant comments?
    Dude, he works in a Harley shop now... what else they go to talk about, new HD technology?
    Ok, here's one that came from my mom (after seeing Narbone's chain break half way through SuMo warm up)
    Mom: "Wow, his bike still has a chain!"
    Me: "All sport bikes have chains, mom."
    Mom: "No, a lot of bikes have belts!"
    Me: "Cruisers like Harleys have belts, which are the lest efficient method of transferring power to the rear wheel. The only sport bikes I know of that use belt drives are Buells, which were made by Harley, so they were going to be a big POS anyway, but it doesn't really matter, Buell stopped making bikes last year."
    Mom: "Well if he had a belt, that wouldn't have happened, so who's stupid now?"
    Me: "Narbone must be stupid... you're right mom. He should totally race a Harley."
    Original
  2. #102
    Me: "Cruisers like Harleys have belts, which are the lest efficient method of transferring power to the rear wheel."
    no it's not
  3. #103
    Tucson, AZ
    no it's not
    Correct me if I'm wrong, but weren't YOU giving Nick shit about how the slack in the belt results in a delay before power is transferred to the rear wheel and also allows for more slipping?
    Original
  4. #104
    If I was, I was just busting his balls. I tell him lots of lies when I'm busting his balls
    Belts really aren't all that bad. The problem I see with belts is they haven't had the same tensile strength (until recently) and your choice of gearing is either reduced or nonexistent. Other than that, they're quieter and require almost no maintenance aside from regular checks to make sure the teeth are okay.
    I'm sure there's plenty of other pros and cons though.
  5. #105
    Jun 2005
    Shaft drive is generally less efficient... Especially in (most) cases where the crankshaft is perpendicular to the shaft. As far as I know belts and chains are more or less equal in terms of efficiency.
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    "Is it fast?"
    My answer...."Def not."
    Tucson, AZ
    I googled a bit and I think the difference is small, but the consensus is that chain drives are more efficient.
    Stated briefly, chain drives are the most economical way to transmit power to the rear wheel. They also convey the greatest percentage of engine power in the process. Chain drives are by far the most popular drive mechanism in motorbikes around the world. On the other hand, they also require the most maintenance, are dirty, and not as smooth as a shaft or belt drive. Bear in mind that the most routine motorcycle maintenance required of a rider is taking care of those metal chain links! (Unless you include putting gas in the tank.) So, reducing that chain maintenance equates to greater rider enjoyment.
    Power transmission chains can be
    categorized as roller chain, engineering
    steel chain, silent chain, detachable
    chain, and offset sidebar chain.
    Some of the advantages of chain
    drives over belt drives are:
    • No slippage between chain and
    sprocket teeth.
    • Negligible stretch, allowing
    chains to carry heavy loads.
    • Long operating life expectancy
    because flexure and friction contact
    occur between hardened bearing surfaces
    separated by an oil film.
    • Operates in hostile environments
    such as high temperatures,
    high moisture or oily areas, dusty,
    dirty, and corrosive atmospheres, etc.,
    especially if high alloy metals and
    other special materials are used.
    • Long shelf life because metal
    chain ordinarily doesn’t deteriorate
    with age and is unaffected by sun,
    reasonable ranges of heat, moisture,
    and oil.
    • Certain types can be replaced
    without disturbing other components
    mounted on the same shafts as
    sprockets.
    Either way, my mom was suggesting that a dirt bike would be better off with a belt drive... which is definitely NOT the case since small amounts of dirt will degrade a belt with a quickness.
    Original
  8. #108
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I had 30K on my HD belt when I totaled the bike. My buddy has over 70K on his belt. Once it has the initial stretch it sets and in my case there was next to 0 maintenance except for looking at it every 8K when I put a new back tire on. I wasn't nice to it either. I probably could have gotten another 30K out of it. Only one I ever heard with a belt issue is loun with his Hyosung. The draw is not easy to change gearing. ( Oh and my new BWM is belt driven )
    But lets get back on subject...
    How do you ride in the rain with out crashing, isn't it slippery?
    It's below freezing out aren't you cold on that thing?
    Posted by Jane in BoxChat
  9. #109
    Senior Member JalopySiR's Avatar
    Dec 2008
    Charleston, SC
    Do they ride bikes, too?
    Did no one else get this? It's hilarious!
    2002 RVT1000R
    1998 VFR800Fi
    2002 CR80RB
  10. #110
    Member Boosh's Avatar
    Nov 2010
    NH
    "There is something wrong with your bike, It's making a clacking sound"
    Quote Originally Posted by Mike Qube View Post
    From a harley type guy "You know Ducati is made by Harley Davidson, it's a VTwin, Harley own the patent on those, they're the only ones who make them. Everyone else just sticks their name on them."
    That has to be a joke! No adult with half a brain would say that.
    Quote Originally Posted by dhuze View Post
    You had the same conversation two days in a row?
    thats weird. my phone did some funky shit this morning. it must have reposted.
  12. #112
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    I'd put money on a higher accident rate per veh mile on a Harley vs a crotch rocket.
    Thats true. Most are on learner permits. When the light turns green and they take their feet of the ground they fall over. Insurance companies hate replacing all that chrome.
    Quote Originally Posted by Rambunctous
    Wha?
    Senior Member Mike Qube's Avatar
    Medford, MA
    Quote Originally Posted by Boosh View Post
    100% serious. It happened to me at a Dunkin in Waltham.
    Jul 2005
    Bennington, NH
    Isn't that an awfully big bike for a girl? (I have an SV650)
    Is that your boyfriend's/husband's/father's/brother's bike?
    You ride? You don't strike me as a "Biker chick"! (OOOHHHH, I hate that term with the condescending tone....)
    Motorcycles are dangerous, you know.
    Now that you have a kid you're going to stop riding right? (I will note that Rob has YET to be asked this question, to my knowledge)
  16. #116
    Lifer mrezra's Avatar
    Rotorua, New Zealand
    Waiting for a boat off MV with several other motorcyclists last year...
    Cruiser Guy: "What's with all the leather? Aren't you hot? It's not like all that stuff makes your rice burner any faster."
    Me: "Rice burner? This is a Triumph. If anything, it runs on boiled cabbage. Besides..."
    Cruiser Guy: "Ahhh, I can't keep all those Jap bikes apart."
    Me: "Isn't your VTX made in Japan?"
    Cruiser Guy: "At least I don't give bikers a bad name."
    Posting Freak khuygie88's Avatar
    Dec 2009
    RI/VT
    Over half of all Harley owners will dump their bikes at one point. It's a statistic.! Ok, one I just made up. It's on the internet forever now so it must be true.
    Now shaddup and
    FACT
    Awwww... shit, drink
    Riding "The Widow Maker" LiterR1's Avatar
    Sep 2010
    Mass
    Parking the bike outside the office
    Old Guy "Is that one of those American Choppers I see on TV"
    Me " No this is what YOU folks call a Rice Rocket. it is Japanese"
    Old Guy " Why do you call it a Rice Rocket"
    Me " I do not. I call it My Sport Bike"
    Old Guy " well what is the Difference"
    Me " Have a Nice day Sir"
    Quote Originally Posted by Danny500 View Post
    Talk about good riders... you are one fun guy to ride with!!
  19. #119
    You ride? You don't strike me as a "Biker chick"! (OOOHHHH, I hate that term with the condescending tone....)/
    Especially if it comes from a guy in his "Badass in a box" costume. Flat black half-helmet, black tshirt, jeans and s-kickers....
    I admit to being anti-social in my old age. I don't take my helmet off at fuel stops, and if anyone says anything even mildly annoying I say "I can't hear you - I have earplugs on" really loudly. Unless it's a kid.
  20. #120
    you can't lean with a car tire
  21. #121
    Nov 2004
    Boston, MA
    Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_2_6 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8E200 Safari/6533.18.5)
    Quote Originally Posted by Sheppo
    How are these ignorant comments?? It is slippery in the rain and mist normal humans are cold when it's below freezing???
    I'm beginning to think people don't understand the thread. Is that ignorant?
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
  22. #122
    Feb 2008
    Las Vegas
    Chillin at a Gas Station, Cop rolls up, looks over and says...
    "You know what Tuono stands for right?"
    Me: "Yea"
    Cop: "Speeding Ticket"
    Me: "More like jail time"
    Cop: "Oh really...?"
    Me: "Actually sir, it means Thunder, Mille stands for criminal speeding..."
    Cop:"I know, I had one."
    Smile, wink, wave...see ya round.
    Actually guy was pretty cool, turns out he had owned a few Aprilia's, which was surprising, cause I thought he was just tring to be an ass.
    Carpe Diem
    '10 Yamaha R6-Race-
  23. #123
    its my understanding that a belt & rotating pullies are lighter than a chain & sprockets and therefore the most effecient, not to say thare aren't disavantages that go along with the efficiency
  24. #124
    Westford, Ma
    You are right... they weren't.
  25. #125
    "You guys who ride them things are insane! Always wheeling and speeding!" Author Unknown.
    Heard this last week when I pulled up to get some gas.
    What about every time you're riding down the street and someone turns around to ask you to wheelie by gesturing with their arms and theirs a car in front of you, or you're coming to a red light??
  1. Sad accident. Interesting comments.
    Last Post: 03-13-12, 11:48 AM
  2. Mladin's comments
    By Paul_E_D in forum Pit Area
    Last Post: 03-09-09, 11:18 PM
  3. My comments on the weekend
    By Degsy in forum Pit Area
    Last Post: 04-29-03, 11:25 PM
