Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Fazzos.....
    Quote Originally Posted by FriskyDingo
    im looking at getting some Fazzos off the ole ebay. im looking at getting some orange ones to match the KTM but im nervous about what the orange actually looks like. in the pics they look good but we all know how that is. anyone get a set of these and are they any good or are they cheap knock offs? i think i remember reading in several places that they are decent levers.
    have you found some that fit the SM? or did you get an SMR? I've been looking for a while, all the ones I find on ebay were for the 690duke/SMR & 990 Super Duke that all use similar remote resevoir Brembo masters.
    Quote Originally Posted by PainfullySlow View Post
    Hey all. As mentioned I can get them. Sadly the KTMs all run a unique clutch lever specific to that brand and I only carry one at a time simply due to lack of demand. Naturally I sold the only one I had last week
    If you make ones that fit the 2007 690SM I'll order a set at the same time so you can at least do 2 sets at once.
    I assume that the duke 690 and the sm are the same. Mine has a magura clutch and brembo brake. Neither are radial. Is the duke a radial master cylinder?
    Hypertarded
    RI / CT border
    Re: Fazzos.....
    yup, besides the sweet Marchesinniss rims on the SMR(making it worth more) it also has different/upgraded Brembo master & levers, same levers as the Duke 690 & 990 super duke. Brake calipers are the same on the duke, SM&SMR, but not the levers/master.
    Duke 690 shares a bunch with the 690SM/SMR, way more than the 690SMC, but the levers/master on the 690 duke & SMR are radial while the 690SM & SMC have the same levers but next to nothing else in common(other than the engine).
    I watched a 2007 690SMR in FL sell for $3,600 yesterday on Ebay, would have scooped it up at that $$$ if it was within 500 miles.
    Re: Fazzos.....
    GOD DAMMIT!! well i guess im NOT getting any levers then. no one makes them for the SM. maybe ill try to find a set of radial clutch and brake masters off of a duke 690
    Re: Fazzos.....
    You sure? Id think asv would.
    Edit
    Re: Fazzos.....
    They're probably just the same as the ktm dirtbike levers. There's plenty of blingy ones of those out there. Turn that frown upside down.
    KB KB's Avatar
    Manchester NH
    Re: Fazzos.....
    Ox sucks!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Kb swallows.
    Unallocated honesty I wasn't looking for bling. Just some cheap shorty levers.
    Dublin, NH
    Re: Fazzos.....
    Well you better reallocate that honesty.
    2023 KTM 890 Adventure R
    Re: Fazzos.....
    Kb swallows.
    Jul 2005
    Bennington, NH
    Re: Fazzos.....
    Rob's got real Pazzos in orange and they seem to be holding color well.
    Senior Member Mike Qube's Avatar
    Medford, MA
    Re: Fazzos.....
    I have fazzos on my Monster. They've been on for over a year now and no issues except some fading.
    Jan 2009
    Middletown, Ct.
    Re: Fazzos.....
    I have real ASV's on my Triumph. 3 years, ride it every day to work over the spring/summer/fall. The sun faded them. The sun will fade anything in the right conditions. Fazzo, Pazzo, ASV, CRG, 434Racing, what ever you put on.
    Re: Fazzos.....
    damn auto correct
    Re: Fazzos.....
    after lots of research ive come up with the following.
    the brake is the same as many Ducatis (any lever that ends in 52 on ASVs site)
    the clutch is the same as the 950/990 adventure and many other KTM dirtbikes
    ASV makes levers that fit, but at $200+ for a pair thats a little steep.
    i can mix and match different manufacturers but its tough if not impossible
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Re: Fazzos.....
    I've read stories of the Fazzos having a poorly dimensioned cam where they pivot against the plunger. With an improper radius or height, the lever can cause the brakes to not completely disengage causing the brakes to drag.
    LRRS 878 Clapped out Gixxah
