Results 1 to 14 of 14
Working with Fiberglass / bodywork - Question
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Is there any easy way to see what you need do a better job sanding BEFORE painting / wrapping the bodywork?
    Mine came out OK - meaning they pass the 100ft or 100mph rule, but there are definitely some random kernels of resin, etc. that I didn't see until the wrap went over them.
    As it was, I would sand, think I was done, feel the bodywork for smoothness, wipe/wash off the dust, then find more spots to sand.
    Should I sand/prime/ then sand again?
    I saw some filler/primer at the store, I'm guessing that would help too....
    LRRS 919
    Windham NH
    Re: Working with Fiberglass / bodywork - Question
    Bondo
    Sep 2013
    Bondo
    Only on my 'busa.
    LRRS 919
    Member martia's Avatar
    Grafton, MA
    Spray with a scratch coat and any low spot fill with glaze And sand high spot.
    Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
    Senior Member Viper897's Avatar
    Apr 2014
    Seacoast Maine
    Whats the progression your using on sand paper? Also bondo or any other crack filler needs to be sanded fairly aggresivly from my experiance. I did a fair bit of body work last year to my SV, 2nd time was extensive fiberglass repair.
    Thin primer coat should show you the imperfections, where you need another round of filler and/or sanding.
    But honestly, it's race body work. At some point the give-a-fuck-o-meter hits zero.
    I'm curious what a vinyl wrap would look like over somewhat imperfect bodywork.
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    What is the consensus on types of rattle can paints and clears to use, to avoid unwanted reactions (cracking) when successive coats are added?
    I'm not concerned at ALL with a fancy looking finish. Just need to fiberglass all the misdrilled holes made by previous owners of the bike and figure I may as well change the color of my race bodywork while I am at it.
    Also, for patching all those holes, seems like the smart way would be to add the fiberglass cloth to the inside of the bodywork and fill the voids after it cures from the outside with resin, right?
    I used tractor paint from tractor supply store. It works, so far.
    Yes on the patch from the inside. Once the resin starts to harden, try to smooth and form it on the outside with your (gloved) hand. As it thickens it becomes a great filler.
    Sep 2012
    Southwick,MA
    I will probably just mix the resin (for when I lay the cloth) so hot that is fully cured in 5-10 minutes and then I can fill the holes from the outside with another batch of resin. Anytime I've ever tried to form resin (with surfboards) while it is curing has been a sticky spider web disaster.
    What mistake are people making with clear coats that they have to sand it off and start over? Is it mixing brands, or types, or not letting coats dry fully, or something else? Seems like I've read enough horror stories that it is kind of common...
    who knows
    Quote Originally Posted by martia View Post
    ^^ what this guy said... you need to use glaze not more bondo to fill in the small imperfections.
    glaze is like spackle for this type of work body.
    go faster cdovego's Avatar
    Weymouth
    Look at my cbr next weekend.
    Central Mass Powersports #123
    You can get guide coat paint and use that: https://www.youtube.com/watch?v=c2e3rACDImU
    Or you can get guide coat powder and use that instead: 3M Dry Guide Coat Applicator Kits 05861 - Free Shipping on Orders Over $99 at Summit Racing
    Hit up YouTube and search for "Kevin Tetz" and watch his videos. It's focused on cars, not bikes, but it's about the right way to do DIY work.
    Posting Freak Gecko's Avatar
    Jul 2008
    ^^ What this guy said ... saying what the other guy said.
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
    Lifer Stromper's Avatar
    Eastern Ct
    You need to block sand to knock down highs and feather stuff
    Hand or soft sanding won't blend them just go over
    The calculus of hate
  1. Fiberglass repair.
    By Johnpewpew in forum Bike Maintenance
    Last Post: 04-13-20, 01:41 AM
  2. For Sale - Parts & Tools | WTT: R6 street bodywork for race bodywork
    By Mr. Kurtz in forum For Sale
    Last Post: 05-04-14, 11:18 AM
  3. Easyfairings.com fiberglass bodywork?
    By Nuss in forum General Bike Related
    Last Post: 07-19-12, 09:52 PM
  4. 05-06 636 E-Racing fiberglass bodywork
    By Io-bot in forum For Sale
    Last Post: 03-29-11, 09:41 AM
  5. Bodywork/tech question
    Last Post: 01-14-10, 07:12 PM
