Results 1 to 21 of 21
Forks...
    Tougher than a lion Sportygurl131's Avatar
    Billerica MA
    Forks...
    So my front forks suck! on my sv650s.. very squishy
    some people replace the oil in forks or the springs etc..
    but im looking to change to gsxr forks
    anyone know any info on this
    year.. stem size etc?
    thanks in advance
    Quote Originally Posted by DuncanMoto
    Subaru love is so sweet.
    qoute from a fellow nesrian
    You crazy bitch!!
    2003 sv650s copper!
    Quote Originally Posted by Duffy View Post
    Sportygurl is probably your best bet for meeting and making new friends, she is like the social director or ambassador or something for NESR.
    Lifer Pittenger5's Avatar
    Austin
    Re: Forks...
    have you had them set up for you? That might be the first step and see how they feel.
    Zip Tie Alley #505
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: Forks...
    currently they are . . . mushy as fuck lol
    aka full compression can occur while i role and grab the brake
    www.bostonmoto.com
    Ride to live, live to ride
    Re: Forks...
    Swap your front end for a GSXR front end....done.
    http://www.parkwaycycle.com/fiche_select.asp
    Microfiche's are your friend. Just look at the triple tree bearing sizes.
    Re: Forks...
    my SV forks are weird. First under hard braking it feels soft and it dives a bit (ive learned to use a bit of rear brake to get the bike to squat instead of dive) .. but then hit a succession of bumps or road features in a row and it feels over damped or something i dunno. also my SV makes some great clunk sounds over stuff like that too, even though everything is tight and in good order. i think just hearing a clunk adds to the effect and makes it worse haha.
    When i ride over the same bumps/roads on a gsx-r it is somehow less dramatic, but it also has a steering dampner so maybe thats adding to the feel. alot of people just upgrade their forks with 20 or 15wt. oil and sonic or racetech springs etc. ALOT cheaper.
    adjusting the settings on our bikes doesnt do much if anything. however i did turn in my front screws about two full turns from stock (more preload but not maxed out), and notched the rear preload up a notch and then put it back to stock. adjusting preload isnt really the problem
    ok shit i didnt comprehend your post.. I have the info for you in one second!
    02 Ninja 250 (sold), K8-SV650S
    Re: Forks...
    booyah! the newer the better!! get some trick black 750 forks
    http://forum.svrider.com/showthread....ork+swap+guide
    Billerica MA
    Re: Forks...
    i just want my forks not to be so squishy... when i stop the squish alot! i mean i dont care what i do but its got to be fixed! so all advice is welcome!
    You crazy bitch!!
    2003 sv650s copper!
    Member Hammerspur's Avatar
    Nov 2009
    Cranston,RI
    Re: Forks...
    I don't know what SV forks look like, presume they're conventional damper rod non-inverted type.
    Simple CHEAP fix:
    If it was me I'd drain them and refill with a bit heavier oil, then preload the springs some while re-assembling.
    Pick up a stack of washers with an OD to match the ID of the fork tubes and place 2 or 3 atop each spring when reassembling.
    You might need to experiment some, add some washers, ride it some and decide if you want a little more.
    I wouldn't advise preloading without going up a bit in oil viscosity as well, and don't overdo that 'uppage' either.
    This simple mod can make a big improvement in feel.
    Less 'squishy', less dive and compression when braking will be slower and more controlled.
    "A skittish motorcycle with a touch of blood in it is better than all the riding animals on Earth."
    T.E. Lawrence
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Re: Forks...
    Jackie have you set your static sag??? It made a world of a difference when I had mine set properly. Also iIt could be that the fork oil in the forks is spent! Time for a visit to GMD computrack! I wouldnt dive into new forks just yet. Try the two options above first and save yourself some money.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: Forks...
    jackie fix up the ones ya got.
    www.bostonmoto.com
    Forum Rules
    Lifer BostonSVkid's Avatar
    Dec 2005
    Re: Forks...
    The issue with the GSXR conversion is the loss of the stearing stop in some situations. IMO I wouldnt suggest you tackle a GSXR conversion unless you have the full scope of what you are getting yoursefl into.
    There are guys at the track running serious times on stock front ends that have been reworked. I would check into that option first. FYI I have owned a 650 before and I just reworked the front end.
    2006 Ducati Monster S2R800
    Lifer DuncanMoto's Avatar
    Re: Forks...
    Rework the current tubes.
    GMD can do it and make it very good.
    Feb 2006
    Metro West, MA
    Re: Forks...
    Quote Originally Posted by DuncanMoto View Post
    +1. They did my static sag for me. I think I'm due for a fluid flush but I'm going to wait till the fall when things are less crazy.
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Re: Forks...
    Do it right the first time, take it to Peter and see what he recommends.
    Dec 2005
    Re: Forks...
    Quote Originally Posted by noxin View Post
    Dont EVEN mention a gsxr fork conversion he hates that shit!
    Member mauro#749's Avatar
    Apr 2010
    ri
    Re: Forks...
    i have the gsxr front on my 05 sv650s, they work grate, i have a set of fork with the treeple, brakes, even the fender, ......i have the all front for sale just 200$, everyting
    High maintenance priss
    Central MA
    Re: Forks...
    Really? Nothing wrong w/ doing a proper conversion. I have had GSXR and Busa forks on my TL, R1 forks on my FZ1, etc...all been by PK.
    Problem is when you just drop something in because it fits and assume its got to be better out of the box because it came from a supersport. It still has to be sprung & valved for your application; and there could be other issues like range of travel, geometry, etc...which may make it less useful than the OEM stuff.
    Sportygurl: I agree w/ the others by first looking at what you can do w/ the OEM suspension. Set sag and damping the best you can. From there, springing and valving can do wonders.
    Dec 2005
    Re: Forks...
    Yeah i talked to him about it when I ahd the SV and he didnt seem a fan of it.
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    Re: Forks...
    you should head over to the SVRider forums... they might be able to tell you about some of your options....
    ..............lol
    hurray, strikethrough!
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: Forks...
    throw on a BUSA FRONT END...I'm assuming Richie is with me on this...
    LRRS #399
    MX #505
    Re: Forks...
    Quote Originally Posted by spicy View Post
    ..............lol
    Best thing I ever did was throw in a set of [Sonic] springs and the emulator was iceing on the cake. See Tricky Mike.
    Here is a link: springs
    and another: svrider
    You can do a lot with the stock suspension, a few guys on SVR have posted incredible lap times with the stock suspension. If you do go the GSXR route, see PK and have him adjust your geometry settings. Also make sure to have the forks revalved for your weight. There is no point in switching to a better setup if it is not tuned for the rider. Pretty pricey for a 'better' suspension, IMO.
  1. Wanted - Parts & Tools | FORKS!
    By lak-o-wits in forum Wanted
    Last Post: 06-14-16, 07:36 AM
  2. box for forks
    By breakdirt916 in forum Wanted
    Last Post: 01-02-11, 01:00 AM
  3. 05 R1 Forks
    By Qfactor in forum For Sale
    Last Post: 11-09-10, 10:00 AM
  4. GSXR GMD forks for Stock forks
    By Kitt in forum For Sale
    Last Post: 09-03-09, 02:37 PM
  5. Forks Please...
    By Femmekat in forum General Bike Related
    Last Post: 08-25-09, 04:32 PM
