Results 1 to 6 of 6
would frame sliders keep you from cracking your fairing if you dropped your bike?
    Central Mass
    ultrabuddy twrayinma's Avatar
    Apr 2002
    albukoikee
    they're supposed to...
    unless they don't stick out far enough, in which case they'd be pretty useless.
    "aaah!" Matt K's Avatar
    Oct 2002
    Acton MA
    If I were you, I'd get a full set of sliders, frame, swingarm, and bar-end. The frame sliders should help protect the fairings (I dunno though, they don't make 'em for my gixxer ), the bar-end ones help keep the brake and clutch levers from getting snapped off, and protect the throttle mechanism on the right side. The Swingarm sliders saved my old muffler from a serious denting. It still got scratched, but the rubber mount let it move over enough that the slider took the weight of the bike, rather than smashing the muffler in. I have heard that sliders will do just that (slide) and thus the bike will slide farther if you fall off it, increasing the chance that it will encounter a solid object, but that's a risk I'll take, to protect it in the much more likely low-speed drops.
    "Balls," I said. "Never mind the track. The track is for punks. We are Road People. We are Cafe Racers."
    - Hunter S Thompson
    2 x 82 GS 650, '94 RM 80
    Uppercrust Euro Rider SilverSurfer's Avatar
    Jan 2002
    Walpole, MA
    Truthfully, no. Frame sliders are meant to protect the frame. Saving the fairings would be a side benefit, but the sliders are usually not designed as fairing savers.
    <table border=0 cellspacing=0 cellpadding=0 width=100%><tr><td background="http://www.nestreetriders.com/images/fill1.gif"><font color=white size=1 face="Trebuchet MS, Arial"><b>SEAN
    01 DAYTONA 955i | 00 DAYTONA 955i | 89 KATANA 600</b></font></td></tr></table>
    RSVMILLE661
    Guest
    If you purchase Frame sliders be sure to get the hard white nylon sliders. Others may look trick or better but tend to shatter when they hit the ground versus slide as they are intended.
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Swingarm sliders can't hurt either. Helps fight the wheels tendency to grab when sliding and send bike into a flip (much more damage then!). Frame sliders will diminish fairing damage but not 100%
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
  1. frame sliders
    By frenchy21 in forum Wanted
    Last Post: 07-31-11, 12:12 PM
  2. Frame Sliders
    By BostonSVkid in forum General Bike Related
    Last Post: 05-18-11, 04:02 PM
  3. Anybody need frame sliders?
    By Kitt in forum Pit Area
    Last Post: 05-10-07, 05:52 AM
  4. frame sliders?
    By Adrenalinechic in forum General Bike Related
    Last Post: 02-03-07, 05:02 PM
  5. Frame sliders
    By snaggle in forum General Bike Related
    Last Post: 11-15-04, 09:08 AM
