Results 1 to 7 of 7
front sprocket/countershaft question
    Gone Fishin' trackdog's Avatar
    Front sprocket(OEM) "floats" on countershaft even though bolt/washer(OEM) torqued to spec. Basically countershaft length or amount it sticks out of transmission is more than the diameter of the sprocket. So, face of countershaft makes contact with washer and there is no contact with the sprocket and it wobbles on the countershaft.
    Is this normal?
    I still love the smell of burnt racing fuel in the morning!
    Member Zero's Avatar
    Nov 2002
    Attleboro, MA
    No that does not seem normal. How about a pic?
    Fiche for VTR1000F
    That is definitel NOT normal. Is this an aftermarket countershaft sprocket?
    derek
    Nov 2002
    Attleboro, MA
    Ok, I have seen the fiche. It is a little different setup than the Suzuki's I usually work on, but it sounds like the width of the sprocket is too thin. Is this the old sprocket, new sprocket, or both? On a Suzuki the trans shaft is threaded and you can just tighten more. This setup actually bottoms out.
    KB KB's Avatar
    Manchester NH
    Sounds like you got either a 525 or a 520 sprocket my man.
    The Superhawk uses a 530 chain.
    Good lock Gary.
    Measure the thickness
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Mechanic that has been working at a local shop rides an '01 Hawk. I asked for his advise and we proceded to the parking lot and removed the slave cylinder/countershaft cover. on his bike..the sprocket does indeed have a little play, just as mine does...His bike's chain and sprocket are O.E. M.....Same amount of play...The D.I.D. chain is O.E.M 530., sprockets are for 530 chains...sized agin the originals.
  1. Front sprocket question
    By wingerdor in forum Dirty Bastards
    Last Post: 08-12-11, 09:16 PM
  2. front sprocket nut
    By Truth in forum Bike Maintenance
    Last Post: 09-06-08, 06:28 PM
  3. Front sprocket help
    By G21forme in forum Bike Maintenance
    Last Post: 07-18-08, 01:28 PM
  4. Afam Front sprocket
    By KillahTillah in forum General Bike Related
    Last Post: 06-09-08, 07:38 PM
  5. countershaft sprocket seal leak
    By chief929 in forum Bike Maintenance
    Last Post: 04-28-08, 06:12 PM
