Results 1 to 25 of 33
Fuel Used
    Southern, NH
    Question Fuel Used
    I have been running the highest octane in
    my 600 and at $3.50/gallon am wondering
    if I will hurt my bike if I alternate between low
    and high grade.
    What is everyone else here putting in their steeds?
    Thanks in advance
    Re: Fuel Used
    Same fuel diff level of octane nothing wrong with running the lower grade in my Gizzxieroni...
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Re: Fuel Used
    Not telling anyone what to put in their bike, but I would never use the cheap stuff. Whats the difference in a 4 gal fill up? Two dollars?
    Im my F150 however, I use the cheap stuff....24gallon tank.
    Sep 2007
    Middlebury VT
    Re: Fuel Used
    I run regular unleaded with no ill effects.
    Member Rossy83's Avatar
    Apr 2008
    Brunswick, ME
    Re: Fuel Used
    With my ZZR I believe it voids any warranty using regular. 90+ Ocatane only. 20c/gal more at 4gal is 80c plus you get slightly better gas mileage with the better gas.
    Northshore/Beverly, MA
    Re: Fuel Used
    Run what they tell you to run...Higher octane does nothing unless you have the compression and ignition lead set for it.
    Cheap costs doesn't mean it's a lower grade fuel
    High octane fuel corrects the detonation issues. It does not "add" horsepower.
    It actually burns slower.
    If the bike doesn't knock and ping, run the lowest you can in it.
    Southern, NH
    Re: Fuel Used
    Thanks for the information everyone
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: Fuel Used
    i think thats the most hilarious myth i've ever heard, i love hearing people say they put 93 in their car and it "felt like a rocket ship"
    Re: Fuel Used
    run the octane that your owners manual calls for
    if it calls for 91 or 93, then you gotta run premium or you'll prollly have detonation
    most new bikes can run on 87/regular unleaded, combustion chambers are so well designed that heat is evenly distributed and premium is no longer "required" for high compression
    Member evile's Avatar
    Apr 2005
    495 - north
    Re: Fuel Used
    I used to have a Saab, if you ran regular gas the ECU would retard timing and reduce turbo pressure to keep it from knocking. This reduced HP and when you filled it up with 93, it would feel like a rocketship again.
    But the bozo who thinks running 93 in a car built for 87 is going to make it faster...RETAHDED.
    Ed
    2001 Ducati ST2
    Canterbury, NH
    Re: Fuel Used
    Quote Originally Posted by evile View Post
    part 1: fine w/e
    part 2: thats what i was thinking...haha
    Sep 2007
    Middlebury VT
    Re: Fuel Used
    Quote Originally Posted by Rossy83 View Post
    If ever their was a bigger myth I'd like to know. Lower grade fuel in 99% of all cases will deliver better mpg only if the engine was designed to run on lower grade.
    Re: Fuel Used
    Quote Originally Posted by Ericthejet View Post
    His engine wasn't designed to run on lower grade.
    His ZZR has a 12.8:1 compression ratio. Kawasaki says "use 91+ only".
    Member XVTer's Avatar
    Sep 2007
    Medfield, MA
    Re: Fuel Used
    I run 93 in my R6. Haven't even tried running anything lower.
    Sep 2007
    Middlebury VT
    Re: Fuel Used
    It would seem like a question with the answer already in hand?
    Id the book says 91+ then run it. Would the manual also mention why not to use a lower grade?
    Lifer Jayspeed's Avatar
    Medford, MA.
    Re: Fuel Used
    +1 on anyone that said what ever your vehicle manual tells you to. Thats all you need. Advancing the ignition timing on your engine will require higher octain is an example to get "the good stuff". Don't waste your money.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    Re: Fuel Used
    There is only one real reason not to use lower octane fuel in higher compression motors, knock. The higher the octane the more resistant it is to detonation. Lower octane fuels can detonate in high compression motors just because of the heat produces by compression, like a diesel. If it does this the expansion from the detonation can cause the piston to be pushed down before it has completed the compression stroke. Which in turn can cause the motor to jump time or parts to break. Using high octane in a motor that has low compression is bad too. Because the motor was not designed to burn as hot you may not be burning all of the fuel in the cylinder which can result in lower MPG, loss of power and carbon build up.
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    Re: Fuel Used
    The speed triple says 91+. I've used 87 and heard a little knocking. Nothing with 89+. I usually use the 91 or 93.
    I put 93 in the sportster once...made it into a friken rocketship
    (just kidding). Seriously though, the sportster manual says 87 is okay and I've never had a problem running the cheap stuff.
    I know there is a bid difference in compression between the two bikes, but I was still surprised.
    2003 R6 - Track
    2000 SV650 - Street/Track
    Feb 2008
    Las Vegas
    Re: Fuel Used
    Quote Originally Posted by BCT748 View Post
    I take back every mean thing I said to you in your introductory thread...well played sir...
    Run the good stuff- 91/93 only in my baby.
    Carpe Diem
    '10 Yamaha R6-Race-
    WoW Josephd14's Avatar
    Fitchburg, MA
    Re: Fuel Used
    Pick one fuel and run it, do not alternate.. if it runs fine on 87 and doesn't ping or knock, then stop wasting your $.40 a gallon, even if you did get more horse power or waht ever on the street which you don't, does it really matter in a bike that will do 150+ Mph no matter what you run in it..
    Sep 2007
    nkRI, nashuaNH
    Re: Fuel Used
    very concise, and exactly right.
    i run 87 in my Bandit
    Southern, NH
    Re: Fuel Used
    Right from the service manual
    FUEL, OIL AND ENGINE COOLANT RECOMMENDATION
    FUEL (FOR USA AND CANADA)
    Use only unleaded gasoline of at least 87 pump octane (R/2 + M/2) or 91 octane or higher rated by the
    research method.
    Gasoline containing MTBE (Methyl Tertiary Butyl Ether), less than 10% ethanol, or less than 5% methanol
    with appropriate cosolvents and corrosion inhibitor is permissible.
    FUEL (FOR OTHER COUNTRIES)
    Gasoline used should be graded 91 octane (Research Method) or higher. Unleaded gasoline is recommended.
    I'm Unique Bowflex's Avatar
    Leominster
    Re: Fuel Used
    I run no lower than 93 octane in my 07' ZZR. I made the mistake of putting 91 in it once...she hated me for a week. Also with the concentration of Ethanol in the fuel getting higher I use a fuel stabilizer to smooth everything out.
    Winchester, MA
    Re: Fuel Used
    Quote Originally Posted by Bowflex View Post
    I think you need to take the folger's challenge.
    Apr 2008
    Salem NH
    Re: Fuel Used
    research method.
    America and Canada use a different way to measure octane than most of the rest of the world. We use an average between the research octane number and motor octane number. Most of the rest of the world just uses the octane number to determine the octane of fuel. The motor octane number is a rating of how the fuel reacts under load so it is a little more accurate.
    Why are you even thinking about using 87 in your bike? The price difference isn't that much when you do the math out. Lets say it costs an extra 40 cents per gallon for 93 and you have a 5 gallon tank. You are only going to be spending an extra $2.00 per fill up. lets say you ride from April to September and you fill up once a week. That means you will fill up your bike 26 times and will cost you a whopping $52.00 more than if you used 87. I think I would rather spend the extra 52 bucks a year rather than worry about jumping time or breaking something in my motor.
  1. fuel
    By PPS26 in forum Pit Area
    Last Post: 06-08-10, 08:11 AM
  2. VP Fuel
    By Big Draggo in forum General Bike Related
    Last Post: 07-10-09, 08:38 PM
  3. VP Fuel
    By derrickhackman in forum Pit Area
    Last Post: 05-06-08, 02:35 PM
  4. Fuel so far?
    By Karaya One in forum Pit Area
    Last Post: 05-21-07, 05:59 PM
