Unofficial self proclaimed official NESR plumber.
"Ah shit son, datz be a Ducati!"-Random kid in Methuen.
get a fucking clue all you fucking idiots
there is no such thing as "cheap stuff" it's all expensive
nor is there a such thing as good stuff here in the US, it's all the same fucking garbage with additives to control the combustion rate
in europe, premium actually does have a higher energy content
if your OM calls for premium, (many bikes do) then use it otherwise your $2/fillup that you don't give a shit about just tells me that your fucking stupid when it comes to spending your money, and that's ok with me
lets say you fill up twice a week. that would be $104.
anyway how do you tell if engine is pinging? cause i can't.
i remember some douche said, for a high octane engine, once in a while fill up with low octane and take it real easy. it'll clean up the crap left by high octane. oh sorry honclif.![]()
"fuckit!"
I run the mid-grade in my Triumph because that's what the manual says to run.
On my car(s), BMW says to run "91K Premium" and there's a lot of debate about what that translates to in the R+M/2 method of octane rating. So a test was in order. I ran through 2 tanks of the mid-grade and got an average of 24.5 MPG. With the 91/93 premium, that went to 25.5 MPG. I thought it was cheaper to run mid-grade, but even with a ten-cent difference in price, the math proved it was cheaper to run premium.
My bike gets similar results. I get about 210 miles out of a tank of regular 87 before the low fuel light hits, but 230 miles with mid-grade. On my bike, I just like to have more range. I notice no difference in performance.
Octane, I believe, is how tight the molecules are bound together. This controls how fast the flame front can tear them apart. Proper rate of expansion of the flame front would, in effect, relate to timing.
It is my understanding that some engines have knock sensors and can advance or retard timing to properly position spark relative to TDC. In an advanced engine with real "3D" ignition mapping and a TPS and O2 sensor some advantage could be gained in efficiency either as it relates to MPG or power output with higher octane.
So, there are circumstances where higher octane will return better results both in performance or mileage (which is a kind of performance) but only in engines designed to take advantage of this.
It is also my understanding that it may be worth it to run higher octane in situations where there is very high ambient temperatures or the engine is being run near it service limits, e.g. at very high RPM.
In either case you'd wind up with high temperature in the combustion chamber and increasing the octane could reduce the possibility of detonation. Conversely an engine may perform better with lower octane when run cold, say running a car engine on many short trips in the winter.
In no case will an engine not equipped with knock sensors perform better when run with higher octane within its service limits.
Me: "Normal people wouldn't do this."
Peter: "First you have to operationalize with normal is."
