Results 1 to 17 of 17
Gear shifting issue??
    Wfd38383 wfd38383's Avatar
    Seekonk
    I don't know if this is a problem with my bike or not. The issue is upshifting from 1st to 2nd gear. When I shift down from N to 1st you hear the normal clunk that you usually hear but when I shift up from 1st to 2nd you feel it go past neutral and then it gets clunky shifting into 2nd gear, almost like it doesn't want to go. The rest of the gears are fine. I don't know if it is a bike issue or is it a normal feeling, or is it a me issue. It seems to get worse the more time I am on the bike consecitively (spelled wicked wrong). Could it be that I am shifting at to high of a speed and that is why it feels clunky? Any help would be greatly appreciated. Thanks in advance.
    It'll usually shift BETTER at higher speeds (revs, really). Tell us more about the bike: year, miles, ever raced, blah-blah-blah...
    Sometimes it's as simple as switching to semi- or full synth erl...
    Lifer Currently's Avatar
    Ooltewah, TN
    Change your oil and then come back and post.
    Personally, I like Rotella T Synthetic.
    You put in what you want as long as it is not energy conserving oil which does not agree with wet clutches.
    yeah, if the oil has a bit of mileage on it, change that first.... that's the easiest & cheapest possible solution.
    Northshore/Beverly, MA
    Check chain tension also...
    Member erik87's Avatar
    Guilford, CT
    are you pulling the clutch in when shifting
    <a href="http://www.sloganizer.net/en/" target="_blank" title="Sloganizer - the slogan generator"><img src="http://www.sloganizer.net/en/image,erik,white,red.png" border="0" alt="generated by sloganizer.net" title="This slogan was generated by sloganizer.net"/></a>
    Quote Originally Posted by erik87 View Post
    For what it's worth, I RARELY use clutches for upshifting...
    Seekonk
    I'm going to change the oil and see how that goes? Yea i'm pulling in the clutch when shifting for every gear. Should I not be?
    You're fine using the clutch, that's what it's for. I prefer not to for upshifts, usually...
    Change the erl and use a semi-synth. Some clutches don't like full-synth, too slippery...
    Apr 2006
    Beverly, MA
    Also pay careful attention to how you're moving your foot to shift. Sometimes I shift a bit too lightly on my SV and it does what you describe. The next shift I use a tiny bit more force and it's perfect.
    Quote Originally Posted by schleppy View Post
    Good point. Zooks aren't especially known for their smooth shifting transmissions...
    Lifer union's Avatar
    Blackstone, MA
    That also goes for shifting too hard. You dont want to stomp on it when you shift.
    James
    if your linkage is clean it shoud shift smooth with the exception of some clunkyness during breakin
    you'd be surprised how much grit can get in the boots over the linkage joints, clean them out and regrease, if you have enuf miles, the linkage may actualy be worn out...enuf to make it bind, especially if you havent been cleaning it regularly
    I've replaced the shift linkage on my SV 3 or 4 times
    Seekonk
    Well I went to my local bike shop and got some oil and a new filter. changed everything and took it for a small drive. The engine seems to run a lot better and smoother but the shifting still seems a little off. I'm going to take it to the shop and have the guys there ride and see if they can see anything. I'll let ya guys know and thanks a messload for the help.
    Don't take it to a shop! They'll fuck ya no matter what!
    There's nothing wrong with it, it's fine. As I said, Zooks don't generally have smooth tranny's. The extra effort is due mostly to the longer throw you have from 1st to 2nd due to neutral being tossed into the mix...
    Flip you shift linkage around so that you have 'GP' shifting. It'll click into 2nd like a well lubed....well, just try it...
    WoW Josephd14's Avatar
    Fitchburg, MA
    No... It's broken, basically it's junk.. You should just give it to me, and call it a loss.. sorry..
    Blackstone, MA
    Quote Originally Posted by wfd38383 View Post
    Seriously dude bring it to me. Ill take it for a spin and give you my honest opinion. You can always bring it to the shop in Bellingham but my hours are limited from now on and Pete is at the race track Monday and Tuesday of this week.
    James
  1. And I'm (finally) shifting!
    By Tspinning in forum Welcome and Intro
    Last Post: 04-10-15, 12:28 AM
  2. 06 GSX-R 1000 shifting issue - air temp related?
    By korndogg in forum Bike Maintenance
    Last Post: 11-10-11, 11:00 AM
  3. GP Shifting
    By nhtodd in forum Bike Maintenance
    Last Post: 08-03-11, 11:31 AM
  4. 92 F2 Shifting issues
    By Deere444H in forum Bike Maintenance
    Last Post: 04-08-10, 04:33 PM
