Results 1 to 17 of 17
GP Shifting Dirt Bikes?
    Winter Test SAB's Avatar
    Does anyone know of a way to reverse the shift pattern on a dirt bike?
    We just picked up a CRF100 this past weekend and we're having way to much in the backyard. The only hang up is that we're all so used to the GP pattern that we keep fooking up our shifts.
    Any suggestions? Thanks! - Seth
    Member Hammerspur's Avatar
    Nov 2009
    Cranston,RI
    Re: GP Shifting Dirt Bikes?
    External linkage like on rearsets with levers in opposing directions... one upward the other down...?
    "A skittish motorcycle with a touch of blood in it is better than all the riding animals on Earth."
    T.E. Lawrence
    WHY???? Its kinda like putting a Brembo or some woodcraft rearsets on it???? and that does killer circle dounts and a great Ice bike also.....
    BTW its a dirt bike>>>
    Yip, some kinda external linkage...
    But do you really have THAT hard of a time with it? Fuck, my streetbike & ALL THREE ATV's all have different patterns = FOUR different shift patterns/techniques...
    external linkage would break every time you fall. Not smart.
    Just Registered Doc's Avatar
    Jericho, VT
    Learn to ride.
    If you all have that much of a problem I think something is wrong. My Trackbikes are GP, the streetbikes are regular. Do I wish they were all one way? Sure.
    Regular shift is easy to remember. When GP shifting I just remember go fast, head down, shift down. Go slow, Pop up, shift up.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    I leave my dirtbikes alone, because I downshift in the air more often then upshift leaned over...
    although GP shift would be dope on a pit bike if it could be done easily... but it can't... U will need a linkage and given the set-up in the pic, I think it would end up handing below the cradle, making it the first thing to bottom.
    The other option is to have someone cut you a new shift drum with the pattern reversed. Given how long that motor design has been around, you may be in luck and able to source a reverse pattern drum from either an import clone motor, or an older Honda model.
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102 UP.Link/6.3.1.20.06.3.1.20.0)
    Not worth the effort.
    Lake Champlain, VT
    my YSR with CR80 swap is GP shift mmmm
    Ah HA!, so you DID get that one. : ) Play with it any yet?
    live to ride seth399's Avatar
    Feb 2007
    CA
    ya dont bother changing, just take time to remember you are on dirtbike shift ehe
    LRRS #399
    MX #505
    Lake Champlain, VT
    if by play with it, you mean... ride it around and almost loop it when it hits the powerband... then yes haha.
    i didn't say I didn't buy the stock one...
    Also met a guy who seemed super interested in your 70.. pm me details and a price.
    Thanks for the advice. Looks like we just need to sack up and learn how to ride it (none of us have had a dirt bike before).
    We spent a few hours after work putting together a mini TT course. We've named it
    "The Isle of Yard". Pics to come. The neighbors officially hate us.
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    i will be over this weekend
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
    Kitaco makes a 'standard' shift pattern drum for the NSF100, which is GP shift out of the crate. It takes the same drum as the CRF100/XR100. The NSF100 is normally GP shift as it has the shift lever aimed back towards the rider instead of forward like the XR100, so switching to the Kitaco drum will give you GP shift with your forward lever, no linkages/etc needed.
    Lake Champlain, VT
    Quote Originally Posted by lrrs699 View Post
    bring a stud kit
  1. 10 year old dirt bikes
    By Tekime in forum General Bike Related
    Last Post: 11-23-17, 07:35 AM
  2. 3 dirt bikes, 1 truck
    Last Post: 09-19-16, 05:59 PM
  3. Dirt Bikes.. not mine!
    Last Post: 03-30-11, 08:45 AM
