Results 1 to 11 of 11
GSXR Owners
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    GSXR Owners
    Apparently this is a comon problem but after all the research and fixes I've tried that worked for everyone else I still havent been able to get my speedo to read anything other than 0mph.
    I've done the common sense fixes like unplugging the speedo wire that goes into the sprocket case from the harness and checked it re-plugged it and nothing..changed the fuses...took off the sprocket case and checked the speedo nut and spacer and everything seems to be fine. The actual reader part isnt chipped or damaged.
    Kitt is nice enough to send me a speedo wire for free to see if thats the issue. Which is saving me from spending 80 bucks on one from the dealer.
    Anyone else have this issue? Is there anything I may have overlooked.
    Just incase someone asks there is a 520 Vortex kit on the bike.
    Re: GSXR Owners
    may want to mention you have a Bazzazz system on there as well
    Gabba Gabba Hey Stiggy's Avatar
    Jan 2009
    Re: GSXR Owners
    Here's a test:
    Unplug that connector from the sprocket case. Attach a multi-meter set to ACv. With bike in nuetral and rear tire off the ground, spin the tire. You should see an AC voltage readout on your meter. Or if your meter can read Hz (frequency), then set it to that. Frequency should increase the faster you spin the tire.
    If that works you can eliminate the pickup coil and reluctor ring inside the case as being the problem.
    Someone correct me if I'm wrong as I'm not familiar with the GSXR specifically, but this is a good way to test speed sensors in general in automotive.
    06 RC46
    Oct 2002
    Cape Cod
    Re: GSXR Owners
    Good call Stiggy...I have a multi-meter at the house. I'll try that when I get off work. Thanks
    Posting Freak senecak19's Avatar
    Massachusetts
    Re: GSXR Owners
    Its probably your sensor wire. I had one die on me. Replaced it and was well.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: GSXR Owners
    Quote Originally Posted by senecak19 View Post
    figured my wire would help him, since i knew you had a problem with one.
    Oct 2002
    Cape Cod
    Re: GSXR Owners
    Cool, Kitt mentioned that you had a similar issue. Thanks for chiming in. Hopefully its just the speed wire..I hate wiring.
    Senior Member Subee13's Avatar
    Feb 2009
    Salem, New Hampshire
    Re: GSXR Owners
    I had a gsxr and i remember people posting about this on gixxer.com. You may want to go there.
    Oct 2002
    Cape Cod
    Re: GSXR Owners
    Update - It was the speed sesor wire that goes into the sprocket cover. THANK YOU Kitt for sending me one. I will now be less paranoid.
    Re: GSXR Owners
    time for wheelies spencer !
    Oct 2002
    Cape Cod
    Re: GSXR Owners
    Why do you think I upgraded my break lines...Stoppie time
  1. 2007 suzuki gsxr 1000 gsxr stator system
    By frenchy21 in forum Wanted
    Last Post: 07-19-12, 01:51 PM
  2. Replies: 5
    Last Post: 03-22-12, 09:42 AM
  3. Replies: 29
    Last Post: 11-21-11, 06:00 PM
  4. Part outs RF, Gsxr 750, Gsxr 1100 Watercooled
    By Madmike in forum For Sale
    Last Post: 01-04-11, 02:02 PM
  5. ATTN: ALL GSXR OWNERS!!!!!!
    By Pigman in forum General Bike Related
    Last Post: 05-01-09, 12:12 PM
