Results 1 to 9 of 9
Help a friend out
    636cc's of fury. 06ZX6R's Avatar
    Sep 2006
    Pembroke, Ma.
    Help a friend out
    Hey guys, a friend of mine is having issues with his bike revving past about 1/4 throttle. He posted on kawiforums but no replies. Hes tearing his hair out, anyone have an idea?
    "Hello all,
    I am looking for some help with a bike I am putting together that has me chasing myself in circles trying to figure out. It is a 91 ZX6c that was a salvage and I have put together from a few parts bikes.
    The problem is that the bike will run and even idle fine but will not pull if given more than about 1/4 throttle. even just free reving it it wont go past about 6k rpm. I have tried two sets of carbs, both of questionable condition, but both with the stock 105 main and 35 pilot jets. I have torn down both sets of carbs multiple times now and they are clean (as best I can see). There is good spark from both the coils and the plugs are brand new, gapped to the factory .028 inch spec.
    I really don't know if this is the proper place to post this question, but I figured that there may be a simple solution to this problem that I am overlooking that is specific to this generation of bike.
    Thanks,
    Owen"
    thanks for lookin guys,
    Alex
    Dec 2003
    Ma
    Help a friend out
    fuel delivery.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Help a friend out
    Originally posted by hessogood
    fuel delivery.
    crack me up
    www.bostonmoto.com
    Forum Rules
    Waterbury, VT
    Help a friend out
    It could be a few things (ignition, fuel delivery, or mechanical). Make sure the fuel is good, filters are clean, carbs are clean, getting the right amount of fuel flow, and you have no vacuum leaks. Make sure the ignition timing is within spec and firing on all the cylinders. Do a compression check and leakdown check. Check to make sure the cams are lined up correctly. A great trouble shoot for hard part problems is to pressurize the cylinders and see where the air is leaking out. Good luck...
    SSearchVT
    Winchester, MA
    Help a friend out
    fuel delivery.
    May 2002
    Meriden CT
    Help a friend out
    Originally posted by Honclfibr
    Make sure his dip sticks got spark plug fluid
    also check the tail pipe for bannanas
    www.bostonmoto.com
    Forum Rules
    Dec 2003
    Ma
    Help a friend out
    I won't be falling for that 'bananas in the tailpipe'
    Help a friend out
    Vacuum leak
    Just Registered Doc's Avatar
    Jericho, VT
    Help a friend out
    +1
  1. My friend's DRZ 400
    By bryco13 in forum For Sale
    Last Post: 07-19-09, 03:13 PM
