Electric pressure washed.
Lol, always a viable backup solution
I emptied a 5x10 storage unit so my moto shed is once again a mess, without enough space to work on a bike.
Clean, Organize, mess up, repeat.
My next solution is to buy another property![]()
Any recommendations for wall mounted shelves?
Would need to anchor into concrete. I have all the tools to do so properly. Something adjustable and not full wall height. I can supply wood for the actual shelving, I'm looking for rail/bracket style setups.
I would go with something like this:
https://www.lowes.com/pd/Style-Selec...pright/4640129
Pretty cheap, they can go out to 24” OC and the brackets can support good weight. Brackets are pretty cheap as well, seems legit. I just did the non adjustable L brackets directly into the studs with 3/4 plywood 16” deep, has worked well. This system looks better for sure.
first, I built a 2x4 insulated walls with drywall, so that I wasn't dealing with fastening to concrete, studs 16" on center, my shelf brackets every other stud, the shelf above my workbench is 18" deep, made out of 5/4 pine, I got some heavy stuff on it, batteries, boxes of parts, I noticed it was sagging, so I added a cable stay every 64", now it's perfectly level and flat, I attached an 8ft led strip underneath to light the workbench. my first attempt at cable stays was a failure, I bought too light a cable, and weak hardware. Couldn't even get it level, as I tightened the turnbuckle, I watched the cable fray apart and eye hooks stretch. I went up to 1/8" cable and compatible hardware,
I wouldn't trust the adjustable brackets on rails (unless it's some industrial setup) for the weight I am storing, tools, batteries, gallons of paint and other liquids. for a bookshelf, sure, but even books will fatigue the brackets and the slots on the rails over time, I figure if my brackets fatigue over time, I just tighten up on the cable stays
Pretty minimalist these days in the main garage.
We have a 60k sqft fab shop 8 miles from home so we don’t need much here.
i would look on CL services or marketplace...or try posting the pavers for free on a local FB group...even try the scrap wood...someone may pick it up to burn in their fire pit...i've gotten rid of a bunch of kids stuff that way...
i think the price of a pickup for these is a little high (almost $300)...could get a dumpster rental for a little more...
https://www.thebagster.com/products/...n_service.aspx
may be too far away...i went to school with the owner of this company...
https://cleanoutcrewma.com/
Any recommendations on bike storage? Will be for my mtb and kids bikes. Would need to store 4 bikes. Does it need to be more complicated than those screw in J hooks?
Oh F yeah!![]()
Jealous. I'm about to embark on a home renovation project and one of the items is to add another garage bay. I think I'm going to do a lift as well.
2003 ZX7R
1995 916
I ended up going with Boston Garage. I think it was about $5500 and it looks amazing. I got probably 5-6 quotes and to be honest they were all within $500 of each other. Boston Garage had the best availability and said they did the most of them (like, several hundred garages a year). Of course, I have no way to verify that number.
