Results 1 to 11 of 11
Help from people that know carb'd bikes
    Jun 2005
    westboro, ma
    I'm trying to bring back a Suzuki Marauder back to ridable condition. The bike is a 2002 that was sitting for a couple years. I replaced the battery added some fuel and tried to start it. No go. Checked fuel flow and there was an issue. The petcock was clogged and upon further inspection the tank was pretty rusty inside. I replaced the petcock and fuel filter, cleaned the tank. The bike starts but runs rough. I'm almost positive it needs the carbs cleaned. My biggest concern is that there is gas coming from the air vent hose on the rear carb. I took it for a quick spin but it left a trail of gas and I got gas all over my leg. Is the carb clogged and it's sending the gas out the airflow line? The bike does seem to be running on both cylinders. I'd much rather do the work myself if it's just a dirty carb.
    Thanks
    Re: Help from people that know carb'd bikes
    sounds like a stuck float to me.
    Pull the carb off, drop the foat bowl, check the needle valve.
    Posting Freak
    New Hampshire
    The float, and or needle and seat is most likely your issue. They get gunked up and bowl keeps filling with fuel.
    Derry NH
    Yeah for sure definitely start with a major cleaning of the carbs. If it's back been sitting more than a few months, it's gonna be pretty dirty and have clogged jets.
    Jun 2005
    westboro, ma
    Thanks for the fast replies. I'll try to clean them tonight and report back.
    Thanks
    V
    Lifer Stromper's Avatar
    Eastern Ct
    Blow out the fuel hoses
    spray gummout down the hose then a air blast if you can.
    once running get a can of seafoam for the next 2 tanks
    Jun 2005
    westboro, ma
    So I bought some Gumout and Seafoam. I went to take the carbs apart but decided to run the bike to drain the fuel in the lines first. It started right up and idled smooth. No fuel all over the place and no bumpy idle. I added more fuel and the Gumout and Seafoam and took it for a few little rides around the block to run some more fuel thru it. She ran great. Backfired a few times but that was my fault, choke was out. I'm totally impressed that after sitting for two years the bike ran as good as it did and with such little work. I'll get it on the road and take it for a ride tomorrow but I'm thinking I won't touch the carbs until winter.
    Thanks for the help.
    I swear by SeaFoam..... stuff kicks ass
    Senior Member Dannyf's Avatar
    Middleboro, MA
    You lucked out. I just had to completely rebuild the carbs on a friend 98 cbr600. Had been sitting on a kickstand for 2 years and the shitty gas that was left in the 2 left carbs destroyed the jets and needles. I dont get why people can't just spend the 5 bucks for fuel stablizer before they hang up the helmet for an extended period of time.
    "When there's a gap you either commit yourself as a professional racing driver that is designed to win races or you come second or you come third or come fifth, and I'm not designed to come third, fourth, or fifth. I race to win, and if you no longer go for a gap that exists, you're no longer a racing driver."
    Ayrton Senna
    Super-Dooper User ɹǝʍoןandɹǝʍoן's Avatar
    Salem NH
    make sure you clean all that carbon buildup while you're riding around
    Quote Originally Posted by Dannyf View Post
    That and they don't exactly teach about fuel stabilizer in driver's ed. 98% people I know wouldn't know fuel stabilizer from koolaid.
    That said, I'm no saint here. Shit happens.
  1. People disrespecting their bikes...
    By bstnsboy in forum General Bike Related
    Last Post: 01-16-12, 06:18 PM
  2. Any Boston people on bikes this evening?
    By irzar6 in forum Rides & Events
    Last Post: 11-08-08, 08:18 PM
  3. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
  4. Carb Tuning people
    By JJ in forum General Bike Related
    Last Post: 08-05-04, 03:59 PM
