BBBBBBBBBB MMMMMMMMMMMM TROUBLE YOU.........................
J/k
Supposed to be great bikes.
It looks like it weighs 800lbs.....
Your 7r needs Atkins...![]()
Yeah, that's the bike!!!
degs
i know you wanna be different but you dont have to go that far.
you will need to get use to the boxer engine. it wants to drop to the right when you rev it.
"fuckit!"
That's a great bike. Handles very well, makes gobs of torque and good power, plus it can really eat up the miles in huge comfort... Build and material quality are very high as well.
Squids ride all kinds of bikes!!! Many Beemer riders are bit nutso. Go for it... if you can afford it![]()
Heh, you might not like that Gear Limited top speed though
Dunno if the boxer cup replica is gear limited given that its a race replica, but most of the BMW bikes (R1150GS for sure, my buddy owns one) are gear limited (in my buddies case, gear limited to 120 mph), and replacing a final drive for higher top end is much more costly than a sprocket/chain swap
Certainly cuts down on certain types of squidly behavior!
Cheers,
Chris
500lb's? That things the Titanic bro!Originally posted by Mystery Squid
505lbs WET BABY!!!
(not MUCH different than my 7R)![]()
Heath Smith
LRRS/CCS #337
Low Down Racing
www.racetireservice.com
www.motorbikesplus.com
Power by Dr. Hillsgrove
Traction by Franimal Racing Syndicate
05' KTM 525SMR,
01' YZ426F
05' Reiju RS1
Says Vale to Colin at the end of the 2002 8 Hours of Suzuka: "Ok Colin, you better go out there and win. Because it is the ONLY way we will NEVER have to come here again!"
BOING!!!!!![]()
That thing looks sweet, I want one!!!
One thing I worry about - does a good rider lean far anough over to grind the valve covers on the pavement???
Yes, it is possible to lean em that far. They do it at the boxer cup races every year(Which is why the boxer cup replica bikes have replaceable carbon fibre valve covers)
Cheers,
Chris
BTW, dragging engine parts is fairly common. inline four motors until like this year were so fat that they dragged on many models (R1, CBR, etc.) at full lean.
The heads on the S drag, but you've got to be really cranked over (race pace) or hitting a transition bump to do it.
I used to drag the case guards on My EX500.
Bouncing off the rev limiter in the top gear on a R1150GS with knobby tires on was an indicated 126. Ie, the gearing of the bike is such that without changing the max RPMs you can't go any faster. My K100RS topped out at roughly 138, also do to gearing limits. With the "trick" lufty final drive you could get up to 146 ('ooh' lol).
These are just the BMW's I have direct experience with, I know for sure that many of the BMW "sports" lineup will do well over 140, and I think the gearing restrictions on the R1150GS at least were due to trying to make the bike pseudo dual use. (In other words I take back the "most BMW bikes", and make that "most BMW bikes I have owned or rode")
Squid litmus test? What are you saying BEEEYOTCH????
LOL That's a GREAT Squid litmus test!
OR, a great Squid line:
"Yo man, that ain't no low-side, I was leaning too far...."![]()
