First of all sorry ive been gone,, I got rid of the Gixxerbut got 3k for it..lol
just picked up a 98 ninja zx7r,,, sat for 3yrs.. dont frickin run,, well before i bought it, it kinda rantook forever..
so heres the scoop
1/2plugs clean and smell like fuel but not soaked
3/4plugs oil fouled bad!!!!!
spark across the board.. compression is good.. only has 7600miles
new fuel,, cleaned the bowls and float needles
someone please please help
i get an occasional blub blub,, stall
Why You Gotta Be Like That !!
ZZZZZOOOM >>>>>>>SPLAT!
the only way to live
New Plugs???![]()
yup
all new ones,, gapped at 28k
Hows your battery? Is there a fuel shutoff valve? Ever crashed? If so is there a fuel cutoff tilt sensor usually in the tailsection. Fuses good. Is the killswitch on the handlebars in the run position?
clean the carbs.......again. and the petcock.
got it,, batt is fresh,, all good never dumped,,,,
will reclean
peace
A sticky float or two? Float height checked across the board? Clean your pilot jets?
Jake
2006 ZX-10R
1999 Kawasaki ZRX1100
pilots done. float level unkown, but not sticky,, should be ok, its all stock..
Sounds like you've flooded it quite badly. I'd pull the plugs, turn the motor several times, then let the cylinders dry out. Have you thought about bad/wet gas?
been there done that,, cleared cylinders, plugs cleaned, fresh 91 octane.
it seems to be getting worse and worse, now doesnt even wanna spark, even though it has spark,, im so tweaked, wish i had bought another gixxer
do you know anything about it's history? Coils/stator? Lemme know if you want to bag it and start looking for another gixxer, I love 7Rs.
quote "cleaned the bowls and float needles"
that's not a carb clean...usually carbs get dipped in solution, metal parts only, remove all plastic and rubber o rings. you need to all the way including sync
as for the spark: it either has it or not... you said the battery was fresh but now run down? (check) weak batteries might give on/off spark make sure the battery is fully charged
gas tank needs to be flushed and the petcock, fuel screen need a good clean out as well.
was it running ok when put away?
gl with that
From what I've seen the bike has great spark and the battery is fine. The guy lives up the road from me that Viper bought it from and I believe he parked it due to having a child more than anything not becasue it crapped out. I know mine was a PITA to start every spring after sitting over the winter even though it was stored in a heated garage. I know were just missing something stupid.
That thing got a KAWI in it?????? SWEEEEEET!!!!!!!
1997 ZX7R LATER JJ
remove air box run it on spray ether...starter fluid
If she seems strong back to the carbs. I assume all jets removed sprayed and blown and replaced.... dribbler/choke non functional ?
Sometimes the rings could be glued in the ring grooves and ass such there be very low compression. A compression check will show you motor health.
Glen Beck is John the Baptist
thanks guys will do tommorow... you have always been better than any forum out there..
will let you know... oh yah.. note: got home today tried again.
backfired through pipe once,, scared the shit outta me..... but still just blub blub,, not real start
Well I'm happy to report that VIPERSRT1 and myself both have the ZX7R's running great. After a total tear down of the carbs on his and fixing a sticky float his is up and running great. And after some small tweaks to mine it's running like a champ once again.
1997 ZX7R LATER JJ
