Got a wiring issue on the RC , I'm guessing ( hoping ) it's something minor . Anybody local that can take a look at it ?![]()
oir work sends our stuff to some guy named sneakers(he is a real odd ball) but he does evertyhing from bikes to ambulences and firetrucks. his shop is located on rt 20 il get the exact info tomm at work if ya want
What kind of issue? I'm not a mechanic, but an electrician that could trace some things out for you depending what it is. Plus I'm very close to you.
5 bucks on bad ground
ill be home after the weekend wouldnt mind giving a hand
the most important choice in life is if you want to be a tigger or a eeyore
Whats it doing OT?
Bruce
2007 VFR800 25th Anniversary
2003 Honda RC51
By not working right, what do you mean exactly? Aftermarket signals will often times flash faster than the o.e.m. signals did, and will require a resistor wired in to slow them back down.
Battery is now dead so I figure there's an open circuit somewhere . Sounds like a ground problem but where to look ? BTW , turn signals were just plain old 2 wire hook ups into the current turn signal wires .
If you attach the old ones does it work?
check all your fuses and make sure the battery terminals are secure, put a charge on the battery and check all your grounds with a test light
