Looking to get a set of Woodcraft frame sliders for the 1000, but not wanting to do this installation myself. It's not like the 900 where the entire hole is on one piece of the fairing.
It's more like a notch in the upper and a hole saw would most likely catch the edge and rip the fairing up.
Here's the installation spot on an 07:
Anyone? Mondo mentioned CEO. Chris, you up for this?
If you reverse the hole saw and press down, it'll make a groove for you to start without ripping it to shit.
Once it establishes the hole, put it in forward and finish it.
I'd consider some masking tape over the area to be removed. Heard it makes things easier in general. Less risk of chipping the paint and hacking the surrounding areas.
Painted up all the plastics for my race bike and forgot about the frame sliders. Learned about the masking tape in the process.
why not use no-cut frame sliders.
KAWASAKI RULES WOOOOO!
chuck, have you seen threads about the laser trick?
with the bolt on stands and no bodywork, put a laser pointer on jack stands and aim it on your engine bolts. then put the bodywork back on, and the laser will still be pointing at exactly where you need to cut
I did them on mine, used a couple self leveling lasers, a milk crate, and some books to get them to the proper height. bike was on stands and locked in place. Measured twice, cut once. They came out PERFECT! Tight Fit & Look Factory.
Used tape where I was cutting the hole. Used a new hole saw. started in reverse, finish in foreward.
I had to think how to tackle it as they cover that whole are on the 09's. Yours looks MUCH easier.
note to self: make sure you tell him you bought NO-CUT sliders before he cuts your bodywork (twice)
Attachment 17820
THAT is a really good idea that I had never thought of. Installing those things is always a tremendous PITA.with the bolt on stands and no bodywork, put a laser pointer on jack stands and aim it on your engine bolts. then put the bodywork back on, and the laser will still be pointing at exactly where you need to cut
Cut from the outside in.
Did this method with my 04RR and it worked perfect. my new bike already had them installed and needless to say he didn't use this method because the holes suck and are ovals.
it's not that hard, just make sure you put the laser pointer far enough away so you don't hit it while putting the fairing back on.
PK gets the answer right. None of you read the initial posting did you?
I DON'T WANT TO DO THIS MYSELF.
- I used masking tape on the 900RR
- I drilled from the outside in on the 900RR
- I don't have a laser level and really don't have any other use for one, so why spend extra $$$
- I'd probably kick something in the process of getting the fairings back on to spot the laser mark on it anyway, since I'm a clumsy oaf.
I simply don't like the idea of cutting the edge of the fairing. Too many things can go wrong. And I'm being lazy.
I read your post. I just didn't offer help.
EDIT: Oh and, nothing goes wrong if you properly mark your drill spot with the fairing mounted then take the fairing off and put a piece of wood behind it and start hacking away.
Sure, 10 minute job
Zip-Tie Alley Racing
LRRS/CCS #103
LRRS/CCS #103
I just finished removing the engine to fix an engine spacer that was smashed by a cheap set of sliders. 3 hours labor and 1 hour machining time. Yeah, please buy the cheap off set sliders, my kid likes to eat......
After you finish putting in a hole with jagged edges you can cover up the butcher work by using a automobile door edge molding. Use a heat gun to get it in there for a nice finish. Your friends will ask you to do theirs. And you can charge them too.
