Results 1 to 10 of 10
Keeping your bike running on the cheap
    Apr 2008
    Boston, MA
    This is an interesting article about a guy who had 440,000 miles on his Honda VFR.
    To summarize:
    Run a good oil filter but run car oil because it is cheaper than motorcycle specific (not in the article but do not run energy conserving oil as the friction modifiers can mess with the clutch)
    RK Chain + Scott oiler for 80k miles on chain
    Re-use tires; plugged tires are perfectly safe if done correctly
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Re: Keeping your bike running on the cheap
    Holy crap...he put 852,000 on a 1990 VFR750....2 motors, one at 412,000 and the other at 440,000
    Lifer ilikenapalm's Avatar
    Connecticut
    Damn. That's $64,000 in gas at today's prices, just on the VFR with 800,000 miles on it.
    I've always run car oils in all my bikes. Never had an issue.
    Mobile 1 Synthetic or traditional Pennzoil dino.
    Lifer markbvt's Avatar
    Georgia, VT
    Guy must be a motorcycle courier. They put on crazy miles.
    If you're changing it often, car oil is fine as long as it's not energy-conserving. But for riders doing more typical mileage, I firmly believe in motorcycle-specific oil. I've tried car oil, and by 3000 miles the engine and transmission felt noticeably less smooth than with motorcycle-specific oil -- transmission gear mesh breaks down the car oil much more quickly (motorcycle oil has a lot more anti-shear additives in it).
    I'm not surprised his engines are lasting so long -- regular mileage with frequent oil changes and regular maintenance is probably a lot better for the engine than low mileage and months between oil changes. But 80k miles out of a chain is damn impressive. I thought I was doing well with over 30k miles on my original V-Strom chain!
    --mark
    Lifer DuncanMoto's Avatar
    Car oil is fine if you're not letting the bike sit.
    I would imagine most people on here do not ride at a frequency where they can give up the motocycle oil friction modifiers with no consequences.
    Member Rusty the Scoob's Avatar
    Concord, MA
    Quote Originally Posted by DuncanMoto View Post
    Hmm... would 2.5 hours, 5 days a week be enough?
    2002 SV650N - Daily Commuter
    www.fennario.us - my Grateful Dead tribute band
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Mobile 1 Synthetic.
    Have run it for years with great results...
    May 2011
    Holyoke, MA
    440,000mi that's impressive for a car!! And 3000mi a week is also very impressive. I used to deliver pizzas and I only put 1000mi a week on my car. hmm at an average of maybe 45mph that is 67 hours a week on the bike. Unless he was speeding down the highway the whole time.. could be going 65 and that would be 46hours a week.. That's still a ton of time on a bike..
    I guess if you want your bike to last you have to ride it often...
    NorthShore
    It's for the gearbox the manufacturers still demand SJ oil. SJ is loaded with zinc (I think they call the add ZDDP) to the tune of 1200PPM which makes a difference to your gearbox, believe it or not. To save the fouling of catalytic converters, Automotive oils have gone down to around 600PPM of zinc or phosphorous (depending on which anti-wear additive a given oil uses) and a lot of them are using calcium as a detergent these days since the demise of SL and SM Havoline from Texaco. That stuff was loaded with moly, 400PPM. High zinc oils are really only necessary in cars that are 2-valves with pushrods and hot cams, heavy valve springs and old-style muscle car cranks and bearings. And motorcycles that share oil with a gearbox. A bike that does a lot of high rpm shifting in the lower gears really stresses and shears the oil pretty badly and the additives in SJ-grades save a lot of wear and tear. If you wipe second gear under warranty they're likely to want to see proof of purchase of SJ if that's what's specified.
    To each their own.
  1. Replies: 16
    Last Post: 06-28-12, 10:01 PM
  2. WTB feeler/advice on a cheap cheap bike for fun
    By rice_rocket in forum Wanted
    Last Post: 04-21-12, 05:01 PM
  3. keeping bike secure in back of truck ???
    By smkn-1 in forum General Bike Related
    Last Post: 05-26-11, 05:35 AM
  4. Keeping My Bike in Boston
    By jmer24 in forum General Bike Related
    Last Post: 03-19-11, 02:26 PM
  5. WTB: Running Dirt Bike- under $1K.
    By McBiggity in forum For Sale
    Last Post: 03-19-09, 11:24 AM
