It's gotta be 'tahded
http://www.bikepics.com/honda/fmx650/05/pics.asp
I like it![]()
They just look like they are tons of fun!
2018 Harley Road Glide
2000 Ducati 900ss
2003 Harley Softail Deuce
I'll also bet it weighs alot relative to it's power. Struggles on highway too. I agree they are cool, but motards lose something when they come from the factory like that. Conversions are way cooler.
'95 ZX7/9
'02 XR650R
'78 KZ1000
Rye, shut up & do a trackday![]()
LOL!
'95 ZX7/9
'02 XR650R
'78 KZ1000
I cant seem to find a listing of this making it to the U.S. ?
That thing looks cool!
www.tailofthedragon.com
As read here: http://www.mcnews.com.au/NewBikeCata...to/intro_b.htm
At the recent Intermot show Honda unveiled a new entrant in to the street biased supermoto class.
While most of the offerings currently in the marketplace lean towards outright performance, somewhat at the expense of practicality and reliability, Honda have chosen to direct their efforts towards commuters and those who want a street based single that promises years of reliable service with minimal servicing requirements.
Providing the get up and go for the 163kg machine is what appears to be the same dependable unit fitted to the NX650 Dominator in recent years. It is an air-cooled RFVC (Radial Four Valve Combustion) single displacing 644cc.
A push-button electric starter and fully electronic ignition combine with the engine’s fully automatic camshaft integrated decompression system for quick and easy one-touch starts in all weather conditions, and a single-shaft balancer reduces vibration.
Ratios in the five-speed gearbox are designed for road use.
The FMX650 features a large-volume, dual-canister stainless steel exhaust system that feeds out in parallel from the engine’s two exhaust ports. Made entirely of stainless steel, the system stands out with its two large-capacity buff-finish silencers reaching upward
The FMX650 frame is of the single backbone variety similar to that seen in the Honda Hornet.
In this application the main backbone acts as the oil reservoir for the dry sump engine. It holds an ample 2.5 litres of oil.
Wide set Gold anodised 45mm upside-down forks control the front of the machine and provide 218mm of travel. At the rear the normal Honda Pro-Link supports the show via a 40mm shock which gives 186mm of travel.
Light alloy rims are shod with 120/70-17 rubber up front and a 150/60-17 at the rear.
Bringing the show to a halt is a twin-piston caliper up front clamping on a large 296mm disc rotor while at the rear a 220mm disc is employed.
Options that are available for the FMX650 include a rear carrier, cargo net, 20mm lower seat, patterned seat skins, various decal sets and handguards. Some of these items appear in the photos we show you on these pages.
At this stage it is unclear if this European developed machine will be available in the Australian market.
Specifications - Honda FMX650 Funmoto
Engine - Air-cooled 4-stroke RFVC SOHC single
Capacity - 644cm3
Bore x Stroke - 100 x 82mm
Compression Ratio - 8.3 : 1
Oil Capacity 2.5 litres
Induction - 40mm VE-type carburettor
Fuel Tank Capacity - 11 litres (including 3.8-litre reserve)
Ignition System - Fully transistorised electronic
Starter - Electric
Clutch - Wet, multiplate with coil springs
Gearbox - Five speed
Frame - Single Cradle Mono-Backbone; Steel tube
Dimensions (LxWxH) - 2,151 x 823 x 1,157mm
Wheelbase - 1,490mm
Seat Height - 875mm
Ground Clearance - 216mm
Dry Weight - 163kg
Front Suspension - 45mm inverted leading-axle telescopic fork, 218mm axle travel
Rear Suspension - Pro-Link, 186mm axle travel
Rims - 17 x 3.5" (F), 17 x 4" (R)
Tyres - 120/70 R17M/C 58H (R) - 150/60 R17M/C 66H (R)
Front Brake - 296 x 4mm hydraulic disc with dual-piston calliper and sintered metal pads
Rear Brake - 220 x 5mm hydraulic disc with single-piston calliper and sintered metal pads
RRP - If sold in Australia this model could be expected to sell for possibly just under $10,000
Hmmm Interesting! Still no implication that it will come here...
Cool bike but i'd still rather a MX bike conversion rather than a factory attempt at a overwieght, underpowered tard![]()
well is a 950cc's enough power for ya
http://www.bikepics.com/highlander/9...ck/02/pics.asp
...what he said!
'95 ZX7/9
'02 XR650R
'78 KZ1000
