OK.. I can draw this up... BUT... you can get reverse electrical function of the switch that has the physical characteristics you want (spring loaded plunger resting @ "in"). Check my work, im a mech e.
You would have 12 V wired up to one lead of the kickstand switch, the other lead going to a 4- prong NC-ST relay (input).
The other 3 prongs on the Relay would be as follows:
1 lead - goes to 10K resistor and 1F capacitor (in parallel), then to ground. (resistor to reduce voltage, capacitor to help bleed bleed current/voltage slowly to prevent shorts.
other 2 leads - in series in the circuit you want to open/close (reverse function to the switch).
I am sure Cole Hersey makes a sw. that you need, they make one for everything else. I use to get them out of a McMaster Carr catalog, but I think you need an account to order from them.
I use to modify vehicles for handicap people, so custom electrics were involved quite a bit. McMaster always had what I needed and were quick to ship.
2018 Harley Road Glide
2000 Ducati 900ss
2003 Harley Softail Deuce
Zip-Tie Alley Racing
LRRS/CCS #103
