Results 1 to 21 of 21
knocked over bike won't start now
    BAMF dingley00's Avatar
    Lincoln, RI
    recently , my bike was vandalized, by being knocked over on both sides. now when i go to start it it won't start. the fuses are fine, and all the lights come on. on the dash the red oil light is on (along with the neutral light), but i don't recall it being on before starting the bike, but maybe it is??
    there isn't even a click or anything .. press the start button absolutely nothing happens..
    what the heck is wrong?
    2010 Kawasaki Z1000
    Just Registered Doc's Avatar
    Jericho, VT
    Re: knocked over bike won't start now
    Tip over sensor?
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    Clutch sensor wire knocked loose?
    Oct 2004
    Southeastern Taxachusetts
    Tip over sensor?
    +1
    have you toggled the engine cut off switch?
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    Lincoln, RI
    what is a tip over sensor (forgive my noobie-ness)? i toggled the kill switch. that's not it.
    i'll have to check the clutch sensor.
    2010 Kawasaki Z1000
    I Void Warranties LowSider's Avatar
    Jul 2005
    Quote Originally Posted by dingley00 View Post
    If a bike is running and is tipped over, it will shut off. It's a safety just like how modern bike won't run while in gear and with the kickstand down.
    In order to turn it back on, the key has to be turned to off and then back on.
    Infected Slyder's Avatar
    Concord, NH
    Does it still crank? It wouldn't crank if the tip-over sensor was stuck would it? Same with the clutch sensor, at least my bike won't crank if the clutch isn't pulled or the stand is down in gear.
    98 Bandit, probably carbed not EFI. If it's carbed and it was on its side it probably washed the cylinders quite well. Hold the throttle wide open and crank it. If you've been cranking it the battery might be too weak to get it to fire, jump it off a car (without the engine running, you won't hurt the car battery at all).....plug your ears, might sound like a shotgun going off
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    There are 4 major safety switches to check.
    Tip over switch
    Clutch switch
    Neutral switch
    Kick stand switch
    You also need to make sure the kill switch wasn't damaged. This is one of those times a shop manual and a volt meter are your friends.
    edit; I'm not sure the 98 Bandit has a tip over switch. my '03 manual is at the shop.
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
    Lincoln, RI
    iti's not cranking at all.. not a noise at all when the button is switched. this is why i think it's a electrical problem.
    2010 Kawasaki Z1000
    Lifer obsolete's Avatar
    Norf Sho
    Do you get power when the key is on?
    -Alex
    Jul 2005
    Sometimes if a battery is very weak, it will be enough to power the lights on the guages but not enough to get anywhere close to crank the engine.
    Is the battery old?
    Have a battery tester/tender?
    Lincoln, RI
    the battery is perfect.
    2010 Kawasaki Z1000
    Nov 2008
    Just remembered. The clutch safety switch is a chronic problem on the Bandit.
    There are two wires that come off the bottom of the clutch handle. Remove and clean the contacts well. This solves the problem 90% of the time. If it doesn't, make a jumper and connect the two wires together. This will bypass the switch. JUST REMEMBER YOU DISABLED IT!!
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Could possibly that its hydrolocked with oil... I know from experience
    but my bike was completely upside down.
    Tip over switch
    Clutch switch
    Neutral switch
    Kick stand switch
    I think if its the tip over sensor the bike will crank but not start though so I'd bet its not that.
    2008 Honda CBR 600RR
    Norf Sho
    Hydro lock would allow the starter to try though wouldn't it?
    Sounds like there is nothing when he hits it. Sounds like a sensor. Start checking them and get back to us.
    -Alex
    Lincoln, RI
    clutch switch,
    kick stand switch
    tip over switch
    neutral switch
    all working fine....
    WTF!?!
    2010 Kawasaki Z1000
    Nov 2008
    Did you check them with a meter? as an example, the clutch switch will make a click noise but no juice will flow.
    Norf Sho
    I would jump them progressively and see what happens.
    -Alex
    Apr 2005
    in the city
    No, nothing can turn over in this situation.
    Waiting for spring Wild.Bill's Avatar
    Jun 2009
    Acton Ma.
    Does your battery have a vent? I have seen batteries empty themself when a bike falls with the vent down. The battery had enough life for the controls but would not turn the starter. Just another idea of something to look at.
    Wild.Bill
    2007 Blue R1 - gone - what next?
    2004 Avalanche
    1985 Corvette
    Flickr
    BillNPhoto Web Page
    Lincoln, RI
    nope check and rechecked the battery. the battery is not the issue.
    i'm stumped, GBM is going to take a look.
    2010 Kawasaki Z1000
  1. Dirt Bike Bump Start with another bike
    By nt650hawk in forum Dirty Bastards
    Last Post: 12-24-15, 06:31 AM
  2. Bike knocked over
    By ae in forum General Bike Related
    Last Post: 12-10-11, 04:42 PM
  3. Someone knocked my bike over: insurance tech?
    By number9 in forum General Bike Related
    Last Post: 08-15-06, 09:28 PM
  4. Sum b*tch knocked my bike over!!!
    By Berto175 in forum General Bike Related
    Last Post: 08-02-04, 12:43 PM
  5. #$%@ knocked my bike over!!!!
    By rockGSX-R750-NH in forum General Bike Related
    Last Post: 05-20-03, 09:01 AM
