Results 1 to 13 of 13
Local Machine Shop?
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Local Machine Shop?
    ok. so I need to bore out the bolt holes on the lower mount of my brandy new Penske shock.
    The mounting hole on the linkage is 12mm, the Penske opening is 10mm.
    any suggestions?
    Jun 2005
    Local Machine Shop?
    I could ream it on my mill (if you're sure of the dimensions) for the cost of the reamer (I don't have a 12mm reamer, but can get one for $20).
    May 2003
    Charlton, MA
    Local Machine Shop?
    It will need to be bored out to 31/64" or .485 "
    Posting Freak rjh200's Avatar
    Chelmsford
    Local Machine Shop?
    Sounds to me like the brandy new penske shock is the wrong one. I could be wrong but I would at least check that out before you drill it out.
    May 2003
    Charlton, MA
    Local Machine Shop?
    ordered right from Mr. Kates.
    Chelmsford
    Local Machine Shop?
    Like I said I am probably wrong. Just sounded weird that a company like Penske would ship a shock that requires boring to be installed. Carry on.
    May 2003
    Charlton, MA
    Local Machine Shop?
    yeah. i know.
    but apparently this is what is done on the ex500's.
    Jun 2005
    Local Machine Shop?
    doesn't sound like a big deal...
    What does the part that needs to be machined look like (is it a through-hole, not blind, can it be removed from the shock, what's it made of, etc?)
    May 2003
    Charlton, MA
    Local Machine Shop?
    i'll post a pic when I get home later
    May 2003
    Charlton, MA
    Local Machine Shop?
    Peter is going to have Penske drop-ship me the clevis with the 12mm hole
    Jun 2005
    Local Machine Shop?
    cool...
    Let me know if you want to bring it over... I'd have to order a reamer from McMaster, but they ship from IL, so it usually arrives next day. Not sure if you'd need it sooner.
    I'm sure any machine shop could handle it. They'll likely just use a boring bar on the lathe, which would be fine, but isn't likely to give you the accuracy of a reamed hole (not likely to matter much, though, given the tolerances are probably +/- .001). They could easily pull it off. The available reamers are 31/64, .4845 and .4850 (tolerances is +.0002).
    May 2003
    Charlton, MA
    Local Machine Shop?
    thanks!
    if they can't get one to me, i'll let you know
    Jun 2005
    Local Machine Shop?
    Cool... a replacement part is def. the way to go. No worries about warranty, etc.
  1. Machine shop in RI or SE MA
    By Zero in forum General Bike Related
    Last Post: 03-01-04, 10:51 PM
  2. Machine Shop?
    Last Post: 12-05-03, 08:36 PM
