Results 1 to 14 of 14
Loctite 648? Anyone have? Suitable substitute?
    Feb 2012
    I'm looking to put my Daytona SUper III back together this weekend and the manual calls for Loctite 648. No one local to me stocks it. My friends have: 680/640/635/620/609/246 compound.
    Can I use one of those instead? Or does anyone have the correct 648 they'd like to lend/sell me?
    Thanks!
    Too many bikes to list
    Mosdt likely drunkd
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Loctite 648? Anyone have? Suitable substitute?
    The calculus of hate
    Feb 2012
    Usually ships in 3 days.
    Yea no.
    Mosdt likely drunkd
    Expert Agitator
    Ashford, CT
    What are you doing with it? Holding gears on a shaft or something?
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    ebay?
    Feb 2012
    Quote Originally Posted by GearHd6 View Post
    Step 1.
    Mosdt likely drunkd
    Haverhill, MA
    Garrett,
    Where are you located? Even if I can find some here at work it may not work depending on your location.
    Joel
    Expert Agitator
    Ashford, CT
    I think he's in Hanover.
    Vibra-tite 548 is the same as Loctite 648.
    Feb 2012
    Yep down in Hanover. A friend of mine has 620 which I read on another forum from a Loctite rep it is the same as 648 but has a higher temp rating.
    Mosdt likely drunkd
    Expert Agitator
    Ashford, CT
    I'm sure the 620 will do what you need it to do. 648 is rapid cure and seems to have a higher shear strength. I'd say the reason for it is to keep that outer bearing race from spinning in the case.
    680 looks like an alternative also.
    Expert Agitator
    Ashford, CT
    Personally, seeing it's the dead of winter I'd order the 648 and put it together another weekend.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    609 retaining compound would do the trick and then some.
    We use it all the time for this type of application at work.
    Haverhill, MA
    Yup, Hanover not so near Haverhill or Peabody.
    Hope you can get your hands on some in the time frame you need it.
    Joel
    Feb 2012
    I pulled the engine apart on Dec 1st. I'm tired of looking at it. I finally got the gaskets I needed this week from Triumph. I have other bikes that need attention too.
    Mosdt likely drunkd
  1. suitable generator for tire warmers?
    By feralchimp in forum General Bike Related
    Last Post: 11-24-24, 05:38 PM
  2. Changing Handelbars/Red Loctite...
    By aweesner in forum Bike Maintenance
    Last Post: 08-03-12, 05:25 PM
  3. Replies: 59
    Last Post: 03-11-10, 09:49 PM
  4. Loctite on Sprocket bolts?
    By idratherberidin in forum Bike Maintenance
    Last Post: 02-22-09, 06:59 PM
  5. Track Day as substitute for Race weekend?
    By lrrs_704 in forum Pit Area
    Last Post: 05-16-07, 04:04 PM
